Yes I have some code ... It is not pretty because I have been doing a lot of debugging with it, but it is functional and may help you to get an idea. I dont store the sequences on the nutduino but rather I use basically brians code except I sned to serial rather than phidgets. On the other end is an app the runs on the Netduino that takes the serial input and turns on the respective relay.I am also working on the same project. Do you have any of the code available (i.e. NetDuino or Brian's code w/o references to the phidget relay). I am looking to create the sequence files on my PC with Brian's code, but store and execute them on the NetDuino.
I have attached my project directory. FYI there is a lot of junk in here but mainly the sequencer app is in the root and the netduino side is in the netduino directory. You are welcome to any of the code here, just remember as I said it may not be pretty
