PWM freezes Netduino in 4.2.0.1 Firmware
#1 daGuy
daGuy
  • 3 posts
Posted 30 October 2012 - 01:07 PM
Hi, I recently flashed the newest Firmware (4.2.0.1) and want to use PWM to control some motors. Whenever I create a PWM instance though the whole device freezes and stops being recognized by windows (immediately when the new object is created it seems). I have to then erase it (with the gold pad) and reflash the complete firmware to fix it. I am using the correct SDK (MicroFrameworkSDK_NETMF42_QFE2.msi) and SDK as specified in the firmware upgrade post. Has anyone else experienced this and is there a solution? Am I missing something? Thank you for help and hints! Jens
#2 NooM
NooM
  • 490 posts
  • LocationAustria
Posted 30 October 2012 - 01:40 PM
how much hz are you using? for me it crashes when using < 100. also you dont have to reflash firmware. go into the bootloder mode, than from mf deploy you can erase just your app (next to the ping button)
#3 Gutworks
Gutworks
  • 363 posts
  • LocationOttawa, Ontario
Posted 30 October 2012 - 04:22 PM
I haven't experienced any issues like this with the latest firmware. Can you post a simple code sample and I will try to reproduce it?
Steve
#4 daGuy
daGuy
  • 3 posts
Posted 30 October 2012 - 10:05 PM
Steve
I actually wrote a new code fragment to test it out and it seems to be working now. I am using this piece:
		PWM pwm = new PWM(PWMChannels.PWM_PIN_D5, 1000, 500, PWM.ScaleFactor.Microseconds, false);
		Boolean ledState = false;
			led.Write(ledState);
			ledState ^= true;
			Thread.Sleep(500);
In retrospect I think I made two mistakes:
1. I used the wrong pin. Wanted to use D5 but started with Cpu.PWMChannel.PWM_5 which Intellisense suggests so very helpfully. I still find it confusing that instead I have to use the wrappers (PWMChannels.PWM_PIN_D5, also for the normal pins)
2. I set the ScaleFactor to Milliseconds and used the values above for period and duration.
So, sorry for the smoke, it seems to work now!
Thank you so much,
Jens
#5 techtoons
techtoons
Posted 16 February 2013 - 06:45 PM
public class Program{	public static void Main()	{		PWM pwm = new PWM(PWMChannels.PWM_PIN_D5, 1000, 500, PWM.ScaleFactor.Microseconds, false);		OutputPort led = new OutputPort(Pins.ONBOARD_LED, false);		Boolean ledState = false;		while (true)		{			led.Write(ledState);			ledState ^= true;			Thread.Sleep(500);		}	}}
In retrospect I think I made two mistakes: 1. I used the wrong pin. Wanted to use D5 but started with Cpu.PWMChannel.PWM_5 which Intellisense suggests so very helpfully. I still find it confusing that instead I have to use the wrappers (PWMChannels.PWM_PIN_D5, also for the normal pins) 2. I set the ScaleFactor to Milliseconds and used the values above for period and duration. So, sorry for the smoke, it seems to work now! Thank you so much, Jens
In your example, what are you using the variable pwm for? It's defined, but doesn't seem to be used.
