Netduino Book - Getting Started with the Internet of Things
#21
Posted 28 May 2011 - 04:59 PM
#22
Posted 28 May 2011 - 07:52 PM
Have you set up your Netduino Plus with an IP address on your local network?I'm trying to follow along with this book but getting discouraged. None of the meaty examples work for me, always ending in a similar error. This part of the program is identifide by debug. I'm just a beginer but I've put some effort into this.
I hope it's ok to post this from the book.
By default, it will try to get a dynamic address, but if for some reason that doesn't work you can set a static IP address as well.
A good follow-up diagnostics step is to try to ping your Netduino Plus from a computer on your network.
Welcome to the Netduino community; let's see if we can get you up and running!
Posted 28 May 2011 - 09:53 PM
#24
Posted 30 May 2011 - 06:47 AM
did you try out the non-Internet examples of the book, such as BlinkingLed? Did they work?
As for the Visual Studio references that are needed in the later examples, maybe you could try out downloading the complete VS projects from my Web site www.gsiot.info/download. They should have set up all references etc. correctly.
Cuno
#25
Posted 30 May 2011 - 11:55 AM
#26
Posted 04 July 2011 - 11:24 PM
(it's the 2nd download)
That helped me determine that dhcp wasn't assigning the address correctly so I switched to a static IP address.
The diagnostic program now runs properly for me. The problem I'm having now is that when I run the HelloPachube
program (the first program example in the book that connects to the internet), it stops after one time through the loop with the output as follows:
sleep for 18130 ms
new message: voltage,1.06
time: 01/01/2009 00:20:40
memory available: 21528
I do see the values were successfully sent to Pachube so the internet connection is working.
I noticed that if I decrease the sampling period from 20 sec to 5 seconds the program runs does more transmissions, one every 5 seconds, but then it eventually stops as well after a minute or less. If I set it to 10 seconds it runs for a few transmissions but then also stops.
Dave
#27
Posted 06 July 2011 - 08:22 AM
if DHCP didn't work correctly, maybe it's a problem with older firmware. Does DHCP work for you with the 4.1.1 beta? If not, Chris would certainly be very interested to learn about that.
I had similar problems with the Pachube examples last year, i.e., a couple of samples have been sent to Pachube successfully, and then the program seemed to stop. But this was with a prototype Netduino Plus, one of the first ten built. After I switched to production boards, I didn't see this problem anymore.
But before betting on a hardware problem, I would try out the 4.1.1 beta firmware, which btw. exhibits the ONBOARD_SW1 behavior that I describe in the box on page 19, unlike earlier versions of the firmware.
Best regards
Cuno
PS
Pachube may still accept new samples every five seconds as they used to do. But officially, they switched to a minimum sampling rate of 12 seconds for free accounts.
#28
Posted 08 July 2011 - 08:06 PM
