I2CDevice extension
22 replies to this topic
#21 Patrick van Es
Patrick van Es
  • 14 posts
Posted 02 December 2010 - 06:32 PM
ok, i finally found the time to do some testing with the following code:
namespace NetduinoAppTest
        static I2CDevice device = null;
            // write your code here
            device = new I2CDevice( new I2CDevice.Configuration(0x42,400));
            device.Execute(new I2CDevice.I2CTransaction[]  {I2CDevice.CreateWriteTransaction(new byte[] { 0x73,0x42, 0x01,0x01,0x70  })}, 20);
The byvac display doesn't even respond. I'm sure I must be doing something wrong but i can't find it..
#22 jbw
jbw
  • 10 posts
Posted 07 December 2010 - 03:21 AM
I'm trying to connect a BMA180 Accelerometer using the I2C connection. I have SDA and SCL to analog pins 4 and 5 respectively. VDD is connected to D1. VIO is connected to D0, which is turned on shortly after VDD is powered (as directed by datasheet). D0 is also connected to CSB, to allow I2C communication (as directed by BMA180 datasheet). I'm using 9 kOhm pullup resistors which are also wired to D0.
At this point I'm just trying to read anything from the device but have had no luck (readBuffer stays at 0). Here's my code, which attempts to access the LSB Z register, which should return something nonzero when the sensor is still (due to the acceleration from gravity).
using CW.NETMF.Hardware;
namespace BMA180
    public class BMA180
            ushort addr = 0x41;
            int clock_freq = 50;
            OutputPort VIO = new OutputPort(Pins.GPIO_PIN_D0, false);
            OutputPort VDD = new OutputPort(Pins.GPIO_PIN_D1, false);
            VDD.Write(true);//Power Sensor
            Thread.Sleep(50);//Wait a bit
            VIO.Write(true);//Power VIO
            byte[] writeBuffer = new byte[1] { 0x06 };//Z-MSB Register
            byte[] readBuffer = new byte[1];
            I2CDevice accelerometer = new I2CDevice(new I2CDevice.Configuration(addr, clock_freq));
            Thread.Sleep(20);
            int test = accelerometer.WriteRead(writeBuffer, readBuffer, 1000, I2COptions.RepeatStart);
#23 Chris Walker
Posted 28 December 2010 - 01:48 AM
Quick update...based on CW2's excellent work, we've added I2C "repeated start bit" extensions to the Netduino v4.1.1 alpha 4 firmware. We're wrapping up testing now (and fixing a few non-related .NET MF bugs), and will post it by the weekend. Chris
