Windows 8 support
Posted 15 October 2012 - 06:37 AM
ntools
http://ntools.codeplex.com/
Posted 15 October 2012 - 07:11 AM
Posted 15 October 2012 - 07:16 AM
Hi Nicky,
I'm running Netduino, Netduino Plus, Netduino Mini, and Netduino Go on my Windows 8 machine. All running the latest firmware.
Netduino Plus uses the new WinUSB drivers. Can you please check that you've updated .NET MF 4.2 to the .NET MF 4.2 QFE2 SDK on your computer?
The machine is at home, so I can't check atm, but I'm nearly a hundred percent sure that I never have had another SDK than 4.2 QFE2 installed. The Windows installation is only about a month old :s
Btw, at first I installed Netduino 4.2 SDK, when that didn't work I removed the Netduino SDK and installed Netduino 4.1 SDK and 4.2 SDK again.
Windows recognised is as a Netduino device, but it just don't show up :s
ntools
Posted 15 October 2012 - 01:42 PM
Posted 15 October 2012 - 03:18 PM
Hi Nicky,
Goddammit.. I have QFE1 installed... I downgraded because I was trying to recompile the source.. idiot.
Thanks Chris! I'll bring my precious with me home one of the next days, and see if that solves the problem.
ntools
Posted 03 May 2013 - 11:37 PM
How do i check that? I have a new Surface Pro Win8 machine and VS2010 and I am trying to deploy to a Netduino Mini and it cant seem to deploy to the device using serial and a selected com port (it selects the com port on its own so i know its sees the device). The deployment and software works fine on my Win7 machine. I really want to get this working on the MS Surface because it makes testing super mobile.
Anybody got simple steps for me to check? Thanks
James
Posted 04 May 2013 - 12:44 AM
Can you try changing your deployment transport (in project properties > .net micro framework) to USB and then back to Serial? To make sure that the serial port selection registered properly? Also...what happens if you try to Ping the device from MFDeploy (Start > .NET Micro Framework > Tools > MFDeploy.exe)? I have a Surface RT, which I love. That Surface Pro of yours is a pretty amazing upgrade; I wish I had one for remote debugging of NETMF apps ChrisHow do i check that? I have a new Surface Pro Win8 machine and VS2010 and I am trying to deploy to a Netduino Mini and it cant seem to deploy to the device using serial and a selected com port (it selects the com port on its own so i know its sees the device). The deployment and software works fine on my Win7 machine. I really want to get this working on the MS Surface because it makes testing super mobile.
