This firmware requires use of the .NET Micro Framework v4.2 SDK (QFE2) and Netduino 4.2.0.1 SDK.
384KB Flash
100KB+ RAM
This firmware includes the following update:
1. New GoBus feature: SerialPort support (COM2/COM3 on Shield Base)
2. New GoBus feature: SPI support (SPI1 on Shield Base)
3. GoBus enhancement: GoBus packets can now span multiple frames
4. GoBus bug fix: single-frame window now enforced for asynchronous events
This update also includes the previous updates:
1. Added preliminary support for GoBus 1.5 beta
2. New GoBus feature: InterruptPort (pins D0, D2-D13 on Shield Base)
3. GoBus 1.5 now supports Virtual I/O from any thread (including events)
To find the current version of your Netduino Go firmware:
3. Plug your Netduino Go into your PC using a Micro USB cable.
4. In the Device section at top, select USB instead of Serial. Your Netduino Go should appear in the drop-down; if not, select it.
To flash this firmware:
1. Detach your Netduino Go
2. Press and hold your Netduino Go's pushbutton while plugging it in via USB; this will put it in bootloader mode.
3. Flash the attached .DFU file using the ST DfuSe Demonstrator application
a. Locate the "Upgrade or Verify Action" pane (bottom-right pane)
b. Press "Choose..." and select the attached DFU file
c. Check the "Verify after download" option
d. Press "Upgrade". It will take a few minutes to update your Netduino Go.
e. Detach and reattach your Netduino Go (power cycle) or press "Leave DFU mode"
If the verification step of flashing fails, erase the chip before re-flashing.
