Compiling and deploying a release code
1 reply to this topic
#1 The3dman
The3dman
  • 9 posts
Posted 04 October 2012 - 07:57 AM
Hi all, After a long debug (with tens of Debug.Print) of my simple web client application, now It seems to work :). So I want to deploy a release code on my netduino plus. In in the Properties window, 1) I set: - Configuration: release under .NET Micro Framework tab - Configuration: release under Debug tab - Configuration: release under Build tab - Output path: \bin\Release under Build tab 2) then I open the Configuration manager from the solution Explorer and from the project list I set my project's configuration as Release 3) Now I can run build solution and deploy directly from the Solution Explorer Is this the correct way to do that? Are there other settings I should care of? Thanks, Andrea
#2 awaiK
awaiK
  • 90 posts
Posted 05 October 2012 - 05:03 PM
Yes, this should work. But step 1 and step 2 are unnecessary. On tab "Debug", "Build", ".NET Micro Framework", etc. you can specify the setting which are used during a build. A shorter way for step 3 is to use the drop-down control right next to the Start Debug button in the toolbar. Note: "Debug" and "Release" are just names for the building template. You can create your own templates to specify your own settings during a build.
