Getting started with Nwazet Display
9 replies to this topic
#1 Bendage
Bendage
  • 153 posts
  • LocationIrvine, CA
Posted 20 September 2012 - 07:44 PM
Whats up everyone,
Finally dusted off my Go. Bought everything months ago but have been so busy with an N+ project its all been sitting in my drawer.
First off, I'd like to say that I am very impressed with the Go and modules being created. Fabien, your nutshell app is genius. Still some bugs in it when trying to change colors of shapes but I can improvise.
I have an issue and a suggestion... issue first.
Downloaded the latest drivers from here ... https://bitbucket.or...f220d46/Library
Created a Go project.
Added Nwazet.Go.SDT028ATFTLCDTS to refs
Made a simple screen canvas via nutshell here...
using SecretLabs.NETMF.Hardware.NetduinoGo;
using Nwazet.Go.Display;
using Nwazet.Go.Imaging;
using Nwazet.Go.Fonts;
namespace DisplayTesting
            // write your code here
            var canvas = new VirtualCanvas(null, null);
            canvas.Initialize(GoSockets.Socket5);
            canvas.SetOrientation(Orientation.Landscape);
            canvas.DrawRectangleRounded(
                11, 33,
                303, 222,
                ColorHelpers.GetRGB24toRGB565(0, 0, 0),
                5,
                RoundedCornerStyle.All);
            canvas.DrawButton(
                245, 190,
                50, 20,
                DejaVuSans9.ID, 12,
                ColorHelpers.GetRGB24toRGB565(233, 114, 114),
                ColorHelpers.GetRGB24toRGB565(255, 255, 255),
                "Button",
                RoundedCornerStyle.None);
            canvas.DrawArrow(
                263, 114, 33,
                DrawingDirection.Right,
                ColorHelpers.GetRGB24toRGB565(172, 220, 102));
            canvas.Execute();
When compiling I am receiving the following errors...
Could not copy the file "C:\Users\bbender\Dropbox\Netduino\Development\Netduino Go\DisplayTesting\DisplayTesting\bin\Debug\LE\Nwazet.Go.Core.pe" because it was not found.
Could not copy the file "C:\Users\bbender\Dropbox\Netduino\Development\Netduino Go\DisplayTesting\DisplayTesting\bin\Debug\LE\Nwazet.Go.SDT028ATFTLCDTS.pe" because it was not found.
I tried referencing the Nwazet.Go.SDT028ATFTLCDTS.dll in two areas of Fabien's BitBucket release...
..\fabienroyer-nwazet.go-b24909aff18e\Library\Nwazet.Go.SDT028ATFTLCDTS\Nwazet.Go.SDT028ATFTLCDTS\bin\Debug
..\fabienroyer-nwazet.go-b24909aff18e\Binaries
No Go! for either reference (pun intended)
Please advise.
Here is also my suggestion...
I looked at the Nwazet product page, this forum (maybe not well enough) and the wiki pages... I really don't see any step by step of exactly what to download and what to reference to get this display fired up. I assumed copy/paste of Nutshell code into my startup program.cs and referencing above mentioned dll but I did not read that it is the correct place or to do that at all. I did load the NwazetDisplayModule.sln provided but it's absolute Go Newb overkill, especially since the SD module has not even been released yet and I don't have a breakout SD.
Is there an instruction page a little less to the extent of taking this display to the max... possibly a more step by step? I realize we are all somewhat engineers or professional tinkerers but until I master the Go! like the plus, I and probably many others would like a dumbed down step by step of hooking the display up to the go, referencing minimum required dlls, and running with code from the nutshell. Maybe even a simple button click event example.
Anything like that as of yet?
BTW... I did read this post... http://forums.netdui...h__1#entry30497
Didn't help. From what I 'think' I know about .pe files being included when ref'ing dlls... my impression is the GAC loads them into your bin. I could be wrong. Perhaps an SDK setup for your drivers with an actual version to go by so we know if we have the latest Fabien?
#2 Fabien Royer
Fabien Royer
  • 406 posts
  • LocationRedmond, WA
Posted 20 September 2012 - 08:44 PM
Hi Bendage,
Sorry that you're having difficulties putting together your project from the binary assemblies.
I'll look into why that is and will make corrections as needed. I've also been thinking about creating tutorials and code snippets, similar to the ones I created for the DAQ module.
In the meantime, you can do the following:
  • Go to the Nwazet source repository and do "Get Source" as a zip file
  • Expand the zip file to a location of your choice
  • Create a Netduino Go! project in VS2010 (any version)
  • Paste the code generated by Nutshell into program.cs
  • Right-click on the solution and do "Add Existing Project..."
  • Add "Nwazet.Go.Core.csproj"
  • Add "Nwazet.Go.Display.csproj"
  • Make "Nwazet.Go.Core" and "Nwazet.Go.Display" dependencies of your main project
  • Compile and deploy :)
See the attached picture to see the completed project.
I hope this helps.
Cheers,
-Fabien.
#3 Bendage
Bendage
  • 153 posts
Posted 20 September 2012 - 08:48 PM
Thanks for the response Fabien. Steps 6-8 are supposed to be mandatory for each project using the display or are you suggesting this a as a 'quick fix' until you solve the .pe deployment dilemma?
#4 GregR
GregR
  • 32 posts
  • LocationKeller, Tx
Posted 20 September 2012 - 08:51 PM
I would like to second this also. A simple setup app that installs the assemblies for those of us that don't need the source, etc. :)
Greg
#5 Fabien Royer
Fabien Royer
  • 406 posts
This will get you unblocked for now :) Both methods should work though and I'll investigate what the issue is as soon as I get the chance. Cheers, -Fabien.
#6 Bendage
Bendage
  • 153 posts
Posted 20 September 2012 - 08:53 PM
Also, I noticed that your reference to the SDT028ATFTLCDTS.dll shows up in your references as Nwazet.Go.Display but the identity in the library reference properties shows Nwazet.Go.SDT028ATFTLCDTS. But when I ref the same library is shows as Nwazet.Go.SDT028ATFTLCDTS. Why is that?
#7 Fabien Royer
Fabien Royer
  • 406 posts
Posted 20 September 2012 - 08:54 PM
GregR, Yup. An installer solution is what we'll be using to simplify things. -Fabien.
#8 Fabien Royer
Fabien Royer
  • 406 posts
Posted 20 September 2012 - 08:58 PM
Bendage, I suspect that something went wrong when I recently merged multiple source trees during the release of the DAQ module code, even though I did a regression pass to make sure all projects built, deployed and ran. -Fabien.
#9 Bendage
Bendage
  • 153 posts
Posted 20 September 2012 - 09:15 PM
Bendage,
-Fabien.
No problem. Looking through your framework, it's very nicely done!
One more stupid question. How to start off by erasing your logo? If I start drawing it draws over it but still shows below it. Is there a ClearScreen() function somewhere?
#10 Fabien Royer
Fabien Royer
  • 406 posts
Posted 20 September 2012 - 09:30 PM
public void DrawFill(ushort color) :)
