With this special build of the firmware, you will have the following resources available for your code:
64KB Flash
28KB RAM
Please note that the TinyBooter bootloader and Netduino firmware must match. If you use this special build of the firmware, you may need to erase and reflash your Netduino Plus with newer firmware releases as well.
EDIT: updated with v4.1.0.5, v4.1.0.6 beta 1, and v4.1.1 alpha 3 firmware
