I am currently building a line-follower. The robot passed the nominal tests on a small black line drawn on a sheet of paper (can detect the line correctly, and switch wheels speeds accordingly).
Now i would like to try a field test.
What would be the best way to have a black path on a white floor? Black line drawn on white paper? Black line drawn on foldable laminated poster board? Black adhesive band on paper? Is there any "ready to print" paths somewhere?
Sorry if the question is a bit out of topic. But if the line follower works, it'll pay off, and I'll have something to show in the "Project showcase" section.
Thank you for your answers,
Farouk
Black line path
Started by Asymptot, Aug 31 2012 12:31 PM
Posted 31 August 2012 - 12:31 PM
Posted 31 August 2012 - 01:01 PM
While it will be a more expensive investment, I've seen many robotics classes use a white board (Dry erase board) lying on a table or floor. This gives you the ability to use a black dry erase marker and redraw the lines easily to show that it does actually follow the line and has not been programmed to repeat a pre-existing path.
It depends on the size of your robot, resp. on the width its sensing mechanism can handle. Usually, a black electrical tape on laminated MDF is used in line follower competitions.
Posted 01 September 2012 - 06:15 AM
Black tape would be good, but my floors at home would be too dark to get a good contrast with the tape. I think you could enhance the tape by using a roll of white paper to create the background onto which the black tape goes. The paper would need to be two or theree times wider than the sensors on the robot. At turnings you may need to put down an A4 sheet to ensure the sensor does not "fall off" the white area.
Paul
Posted 01 September 2012 - 06:41 AM
Just had another thought. I did some brick work a while ago and had to buy a roll of thick black plastic "damp proof course". Since it comes on a very long (30m) roll, most of it is left over in my loft.
Another idea would be to adjust the software to follow a white line on a black background and use the DPC roll as a road, with white insulation tape stuck onto it. It is quite easy to cut with a knife or scisors, and comes in wider sizes if needed. DPC at B&Q in the UK
