GoPort IDC Headers (surface mount) now available
Posted 29 August 2012 - 06:26 PM
These are the same black headers found on Nwazet GoBus modules, Komodex GoBus modules, etc.
Amazon.com: GoPort IDC Headers (10 pack) -- Surface Mount
For those outside of the USA, your favorite Netduino authorized reseller can order these in as well. The PN is "goportheader_sm_10pack".
We should receive the through-hole versions of these headers in about 4-6 weeks. We'll have our photographer take photos of both types once they arrive...but in the meantime we wanted to make the SMD versions available.
Posted 09 September 2012 - 10:34 AM
It is IDC shrouded male headers with 0.05" spacing frm amazon?
There r no specification.
Posted 09 September 2012 - 11:16 AM
Posted 09 September 2012 - 11:28 AM
they are the surface mount versions I.e don't have pins that stick through the board
As Chris's post says they are the ones used by the various 3rd party module builders
Nak.
Thank. I can use male pin headers for breadboard
Posted 09 September 2012 - 11:38 AM
Posted 09 September 2012 - 02:24 PM
Asbjørn
Posted 09 September 2012 - 03:13 PM
If Komodex do not have any of their breakout boards available then you could look at the Make Bread module. The pin headers are not marked correctly for GoBus but they do allow you to breakout the IDC header if you want to look at module development.Or this:
http://www.proto-adv...IDC_Adapter.php
The komodex one would be nice, but where to buy?
And the reason that you cannot use the idc header on an breadboard, is the density of the pins, breadboards use 0.1" / 2.54mm pitch, and these are 0.05"/1.27mm pitch. That dense breadboards are less usefull
I can recommend the Komodex module though as it allows you to connect the ST-Link directly to the breadboard or have a pass through from the Netduino GO! - it's a cracking little board. I use it as my primary method of connecting to the STM8S even when I'm, not doing any module development.
- supra likes this
Posted 09 September 2012 - 03:28 PM
I should have these back in stock in a few weeks. I'll make a post in the forums when they're available.
Matt
- Arron Chapman and neslekkim like this
Posted 09 September 2012 - 04:24 PM
Excellent!. That is what I'm looking for to fix inside scale model 1:64 remote car and also can fix 5-finger arm-bot.
Posted 09 September 2012 - 04:27 PM
Or this:
I needed 90 degrees IDC shrouded male header to fix my remote car and also 5-finger arm-bot
Posted 10 September 2012 - 01:09 AM
Great! Looking forward to it.Hi neslekkim,
Matt
