Hi all,
I know that there are a lot of threads about the use of a Wifi module with Netduino. However not all solution are completely.
I tried following some tutorial with a Wifly shield without success.
Now, I'm looking for a working solution to have wifi connection with Netdudino+. No matter the price.
Can you suggest to me some directions ?
thank you
Roberto
Netduino+ and Wifi
Started by Noce2k, Aug 27 2012 10:40 AM
6 replies to this topic
Posted 27 August 2012 - 10:40 AM
Posted 27 August 2012 - 11:08 AM
I have got only one wifi solution working, but with some limitations. So I wonder;
what kind of data are you going to transfer? As a server or client?
Posted 27 August 2012 - 12:53 PM
The primary goal is "client". I have some ideas about gadgets that invoke internet services and read/write, tipically using REST (so few data).
Anyway, in the future I can be interested also for a server implementation.
What kind of limitations do you refer ? using for example XBEE module ?
thanks
Roberto
thanks
Roberto
Posted 27 August 2012 - 02:50 PM
I indeed used a Wifi-module of the size of a XBee module, but that can only maintain one socket at the time.
Also, there are wired->wireless bridges that you could use, so the wifi isn't done on the netduino but in some other piece of hardware.
Posted 27 August 2012 - 04:31 PM
Not sure if this will help, but I ended up using a TiVo wireless N adapter that I already had and it works great. It has a cat5 cable and RJ-45 connector that plugs right into the ethernet port on the Netduino Plus. The other thing I like about it is the WPS capability for security with the router. I had it up and going in just a few minutes.
They can be found pretty cheap on eBay.
The other thing I like is that it shows the Netduino's MAC address in my router's client list and the IP address gets assigned to the Netduino. Since I am new to Netduino I don't know if there are ever problems otherwise but was happy to see that the wireless adapter just acts as an extension.
Other quick note is I am using a Belkin router but I would think could use other routers (it has the ability to enter encryption key if you don't have WPS on your router), and the adapter needs a power source.
I hope this helps.
Don
I hope this helps.
Don
Posted 27 August 2012 - 06:21 PM
Hi Noce2k,
See Post 2,
http://forums.netdui...ireless-bridge/
There is a newer cheaper n version of the ASUS,
http://www.amazon.co...G/ref=pd_cp_e_0
Baxter
Posted 17 September 2012 - 05:03 AM
Hi Noce,
I hope you can check this thread. It will help you to find a module for your project.
http://forums.netdui...topic=5093&st=0
