Successful compilation of netduino plus 4.1 with rvds 4.0 compiler
No replies to this topic
#1 yiulsup
yiulsup
  • 34 posts
Posted 08 August 2012 - 06:53 AM
Hi Netduino Plus Community. I make post on netduino plus community about compilation of netduino plus firmware 4.1.0.6 with rvds 4.0 of evaluation from ARM Co., Ltd. This is successful story with working well in board which has the .net mf 4.1, netduino plus firmware 4.1.0.6 and tinybooterdecompressor. The steps i taken are follow. 1. To check the .net 4.0 and visual studio 10.0 on your windows 7 machine. adding : If there is some unsure in installing .net 4.0 and visual studio 10.0, Pls reinstall the visual studio 10.0 without hesitation. Pay attention here. Very Important for your compilation. if there is some error in your compilation and deploying the ER_FLASH and ER_CONFIG, this may cause you difficulty. 2. To install the .net micro framework sdk 4.1 3. To install the .net mciro framework porting kit 4.1. 3. To install the netduino plus firmware 4.1.0.6. 4. To install the rvds 4.0 toolchain from ARM Co., Ltd. on path c:\rvds adding : If you download the rvds 4.1 toolchain with evaluation from ARM Co., Ltd. you will meet some error withour answer. version 4.0 is right for your compilation. 5. run as administrator the command. 6. run the command "call "c:\program files (x86)\microsoft visual stduio 10.0\VC\vcvarsall" x86_amd64" 7. run the command in path c:\PK_4.1\setenv_rvds4.0.cmd c:\rvds 8. run the command in path c:\PK_4.1\Soluations\NetduinoPlus\msbuild /t:build /p:flavor=release;tcp_ip_stack=lwip /v:m /m 9. Some error in compilation occured, So need correction with followings. 9-1. platform_selector.h issue. 9-2. lwip_selector.h issue 9-3. armcc path issue 10. There is binary code such as ER_FLASH and ER_CONFIG after compilation without error and with many warnings. Thanks. Kevin.
