COM1 is D0,D1
COM2 is D2,D3
Is it possible to create a COM3 on some other pins, and if so what should I read first?
I have a GPS shield on COM1, a SM5100B GPRS shield on COM2 and I'd like to connect multiple servo controllers on COM3. Luckily the servo controllers are designed to share a single COM port - you assign each controller a different ID number and broadcast commands on the serial port; a controller will only execute those commands addressed to it.
I'm building robot spiders as part of my plan for world domination.
COM3
Started by Arbiter, Jul 31 2012 02:31 AM
Posted 31 July 2012 - 02:31 AM
Posted 31 July 2012 - 03:13 AM
Hi Arbiter,
The serial ports are hardware serial ports. There are two on Netduino Plus (which you're using right now).
Just FYI...the new Shield Base has an additional serial port (COM3) on pins D7/D8. If you want to deploy your NETMF code directly to the Shield Base you can use it today. We'll also be enabling its use from the Netduino Go mainboard shortly...
Posted 31 July 2012 - 05:44 AM
Thanks Chris.
It's not vital, I am simply exploring my options.
Though I may use Go for the spider project it is inherently an exercise in distributed processing. It is likely that each leg will have its own Go or N+ and these will in turn be coordinated by a central board (or even a full scale computer). N+ has built in ethernet which is the ultimate bus; if I do it that way the ganglia don't need GPS and comms is via ethernet rather than GPRS, and the unit that does have GPS and GPRS doesn't connect directly to any servo controllers.
What are the PWM options for Go?
Posted 31 July 2012 - 06:07 AM
The Shield Base has 6 PWMs, and we're working on a Motor Driver module. Other may be working on some PWM-related options as well...What are the PWM options for Go?
