Netduino TankBot
18 replies to this topic
#1 Omar (OZ)
Omar (OZ)
  • 564 posts
Posted 07 October 2010 - 08:21 PM
*Webmaster please move this to the Projects Showcase, thanks* I have stopped my random projects. I am now using the netduino for a project in computer class. I got my idea laid out and hopefully I can take it to some competitions and spread the word about the netduino. (OLD DELETED) UPDATE 10/15/10: The SN754410 Quad Half H-Bridge works GREAT with the netduino! I will try to post some code and diagrams soon. I have to get the Frizing program, I think thats what its called anyways. If you would like to see a sneak peek video go to http://oz.heliohost..../First_Look.wmv NOTE: The video should open in Windows Media Player right away, or download. Added: Diagram of Setup: Attached File  Netduino Two Motors.png   98.65KB   80 downloads Note: Vcc1 is where Netduino 5V goes into and Vcc2 is where battery V goes into. Use those as a reffrence. Also thanks to CW2 for the Netduino Part (http://forums.netdui...-fritzing-part/)
Posted 07 October 2010 - 10:04 PM
Oz, Do you want to use a motor (variable speed) or a servo (precise precision)? Most of the shields should work fine--although you only have 4 hardware PWM instead of 6. [But they're 16-bit instead of 8-bit, so that's a bonus.] So just make sure that the motors/servo connections you want to control are on the "middle 4" of the PWM pins. BTW, it's possible to create software PWM for 1-2 pins pretty easily...to match the six PWMs on the Arduino. Chris
#3 Omar (OZ)
Omar (OZ)
  • 564 posts
Posted 07 October 2010 - 10:28 PM
Oz,
probably motors, and maybe servos if I get to expand the project a little. so it is possible to get the motor shield from adafruit to work? and you know of other ones then I'd be glad to take a look at those too.
#4 Chris Walker
Posted 07 October 2010 - 10:36 PM
The Adafruit shield should work fine--and the DFRobot shield should work fine too. But perhaps someone else here has a motor shield and can pitch in... Chris
#5 ajcg1973
ajcg1973
  • 71 posts
Posted 08 October 2010 - 07:07 PM
While not a shield, I have found the TB6612FNG to be a great IC to use with low voltage motors. SparkFun sells a breakout board for the chip here (http://www.sparkfun....roducts_id=9457) for only $9.
Here is a simple class that I wrote to interface to the chip:
namespace AJB_NetMF_Classes
	public class AjbMotorTB6612FNG
		private PWM _motor1;
		private uint _motor1Speed = 0;
		private OutputPort _motor1PinA;
		private OutputPort _motor1PinB;
		private MotorDirection _motor1Direction;
		private PWM _motor2;
		private uint _motor2Speed = 0;
		private OutputPort _motor2PinA;
		private OutputPort _motor2PinB;
		private MotorDirection _motor2Direction;
		private bool _usingBothMotors = false;
		private bool _isDisposed = false;
		public enum MotorDirection
			Forward,
			Reverse,
			Stop
		public uint Motor1Speed
			get { return _motor1Speed; }
			set
				if ((value <= 100) && (value >= 0))
					_motor1Speed = value;
				_motor1.SetDutyCycle(_motor1Speed);
		public uint Motor2Speed
			get { return _motor2Speed; }
			set
					_motor2Speed = value;
				_motor2.SetDutyCycle(_motor2Speed);
		public MotorDirection Motor1Direction
			get { return _motor1Direction; }
			set
				switch (value)
					case MotorDirection.Forward:
						_motor1Direction = MotorDirection.Forward;
						_motor1PinA.Write(false);
						_motor1PinB.Write(true);
						break;
					case MotorDirection.Reverse:
						_motor1Direction = MotorDirection.Reverse;
						_motor1PinA.Write(true);
						_motor1PinB.Write(false);
						break;
					case MotorDirection.Stop:
						_motor1Direction = MotorDirection.Stop;
						break;
		public MotorDirection Motor2Direction
			get { return _motor2Direction; }
			set
				switch (value)
						_motor2Direction = MotorDirection.Forward;
						_motor2PinA.Write(false);
						_motor2PinB.Write(true);
						break;
						_motor2Direction = MotorDirection.Reverse;
						_motor2PinA.Write(true);
						_motor2PinB.Write(false);
						break;
						_motor2Direction = MotorDirection.Stop;
						break;
		// Construtor for a single motor
		public AjbMotorTB6612FNG(Cpu.Pin motor1Pwm, Cpu.Pin motor1DirectionA, Cpu.Pin motor1DirectionB)
			_motor1PinA = new OutputPort(motor1DirectionA, false);
			_motor1PinB = new OutputPort(motor1DirectionB, false);
			_motor1 = new PWM(motor1Pwm);
		// Construtor for dual motors
		public AjbMotorTB6612FNG(Cpu.Pin motor1Pwm, Cpu.Pin motor1DirectionA, Cpu.Pin motor1DirectionB, Cpu.Pin motor2Pwm, Cpu.Pin motor2DirectionA, Cpu.Pin motor2DirectionB)
			_motor2PinA = new OutputPort(motor2DirectionA, false);
			_motor2PinB = new OutputPort(motor2DirectionB, false);
			_motor2 = new PWM(motor2Pwm);
			_usingBothMotors = true;
		public void Dispose()
			this.Dispose(true);
			GC.SuppressFinalize(this);
		private void Dispose(bool disposing)
			if (!_isDisposed)
				_motor1.SetDutyCycle(0);
				if (_usingBothMotors)
					_motor2.SetDutyCycle(0);
				_isDisposed = true;
		~AjbMotorTB6612FNG()
			this.Dispose(false);
And here is how you would use it:
AjbMotorTB6612FNG motors = new AjbMotorTB6612FNG(Pins.GPIO_PIN_D5, Pins.GPIO_PIN_D11, Pins.GPIO_PIN_D12);
motors.Motor1Direction = AjbMotorTB6612FNG.MotorDirection.Forward;
motors.Motor1Speed = 10;  // Set the motor to 10% speed
#6 Omar (OZ)
Omar (OZ)
  • 564 posts
Posted 09 October 2010 - 12:30 AM
I've decided on the Adafruit shield since it's not too pricey and can drive enough motors. Once they get some things back in stock I'll order a motor shield. Then I can take suggestions on how to write my own library. Chris, do you guys plan on testing or writing a library for the Motor Shield sometime soon?
#7 Chris Walker
Posted 09 October 2010 - 02:55 AM
Hi oz, We'll look at writing a driver, but it'll be a bit before we can get to it... For most motor and servo control, you'll just use PWM--but there may be a special "motor control IC" on there which requires SPI/I2C communication... Chris
#8 Omar (OZ)
Omar (OZ)
  • 564 posts
Posted 09 October 2010 - 03:04 AM
Hi oz,
Alright thanks for the heads up, I'll make sure I read the specs carefully before I buy.
#9 ajcg1973
ajcg1973
  • 71 posts
Posted 09 October 2010 - 06:51 AM
Two suggestions after a quick glance at the product page...
Since the product comes as a kit and soldering is involved anyway, I would suggest that you solder on sockets under the L293D's in case of disaster (which can happen quite easily with motors), that way you can replace the IC's very easily.
If you have the few extra dollars, I would look at purchasing a couple of SN754410 chips as they are a drop-in replacement of the 293D but instead of the 600mA current they can drive up to 1000mA (almost double that of a L293D's sustained and max currents).
Hope that helps...
#10 Omar (OZ)
Omar (OZ)
  • 564 posts
Posted 09 October 2010 - 03:24 PM
Hope that helps...
I realized that I have to solder now.... I dont have a good soldering Iron, that might put a hold on ordering that. Anyways thanks for the suggestions, I'll get the sockets at least.
#11 Omar (OZ)
Omar (OZ)
  • 564 posts
Posted 10 October 2010 - 01:54 AM
I fell in love with this... http://www.sparkfun....products_id=315
I feel like it would teach me SOOO much if I wire it up myself. Also its made by TI and I love my TI-84 Plus SE, it helps in trig class :P
I like so much because its perfect for: http://www.sparkfun....products_id=319 and that would make a sweet car for my project.
After that I can mount some sensors and programm it up.
What do you think?
EDIT:
I found this video... its exatly what I want to do. I am glad I found it cuz it gave me an idea of how big the thing is:
#12 Chris Walker
Posted 10 October 2010 - 10:47 AM
That looks very cool, oz. Just make sure that your H-Bridge drivers will recognize 3.3V TTL signals and you should be good to go... Chris
#13 Omar (OZ)
Omar (OZ)
  • 564 posts
Posted 10 October 2010 - 02:21 PM
I amot reall sure what that mean :| but the data sheet is here: http://www.sparkfun....IC/SN754410.pdf
and here is some info from it
[qoute]
recommended operating conditions
MIN MAX UNIT
Output supply voltage, VCC1 4.5 5.5 V
Output supply voltage, VCC2 4.5 36 V
High-level input voltage, VIH 2 5.5 V
Low-level input voltage, VIL –0.3‡ 0.8 V
Operating virtual junction temperature, TJ –40 125 °C
Operating free-air temperature, TA –40 85 °C
[/qoute]
So I'll probably need lots of help figuring out how to use it, or I might figure it out after reading the datasheet OVER and OVER again. At least when I print that data sheet and brign it to my teacher she'll be happy that I'm trying to do something challenging :D
#14 Chris Walker
Posted 10 October 2010 - 02:42 PM
It looks like 2-5.5V input is supported--so you should be fine. Chris
#15 Omar (OZ)
Omar (OZ)
  • 564 posts
Posted 10 October 2010 - 03:06 PM
great! thanks for the help... How do you think this will do in a science fair? My teacher said not many people are doing the computer science section.
#16 Chris Walker
Posted 10 October 2010 - 03:15 PM
Hopefully it'll do awesome at the science fair...but I don't really know what people are building for science fairs these days.
#17 Omar (OZ)
Omar (OZ)
  • 564 posts
Posted 10 October 2010 - 03:21 PM
Thats true, there no way to know...
I am right on the confirm order page and I just thought about something... Will that little chip fit on a breadboard? i have the half-size breadboard from adafruit (http://www.adafruit....&products_id=64). I need to figure that out, if you can before I do, please tell me.
Oh this might not be good... "Capable of driving high voltage motors using TTL 5V logic levels" it says right on the product page.
EDIT:
So it LOOKS like it will fit on a breadboard. but I'll email them and ask.
"Capable of driving high voltage motors using TTL 5V logic levels" I guess capable means it is possible but not neccesary tp use 5V, again I'll ask.
#18 Chris Walker
Posted 10 October 2010 - 03:32 PM
I'd drop the reseller or manufacturer a line and double-check with them... They should also be able to advise you on size, breadboards, etc.
#19 Omar (OZ)
Omar (OZ)
  • 564 posts
Posted 10 October 2010 - 07:14 PM
well I emailed them about the TTL and breadboard. i scaled the pictures of breadboard and the chip, and they fit. I also saw another video which had the chip on a breadboard. Now I just need the people to get back to me about the TTL thing
