Problem Detect the presence of SD in Netduino Plus
8 replies to this topic
#1 BrunoPescarolli
BrunoPescarolli
  • 14 posts
  • LocationBrazil
Posted 19 July 2012 - 10:23 PM
Hello
I am setting up a code to detect the presence of the Micro Sd with Netduino Plus.
using System.Net;
using System.IO;
using SecretLabs.NETMF.IO;
using Microsoft.SPOT.Net;
public class SD_CARD1
    static InterruptPort SDPORTA = new InterruptPort((Cpu.Pin)57, false, Port.ResistorMode.PullUp, Port.InterruptMode.InterruptEdgeBoth);
       OutputPort SD = new OutputPort((Cpu.Pin)25, false);
       InputPort SD_DETECTADO = new InputPort((Cpu.Pin)57, false, Port.ResistorMode.PullUp);
       Debug.Print("SD CARD DETECTADO!" + (SD_DETECTADO.Read().ToString()));
       SD_DETECTADO.Dispose();
       SDPORTA.OnInterrupt += SDPORTA_OnInterrupt;
   static void SDPORTA_OnInterrupt(uint data1, uint data2, DateTime data)
       Debug.Print("SD CARD foi: " + ((!SDPORTA.Read()) ? "LOCALIZADO" : "REMOVIDO"));
By compiling the code OK! but when you start the application returns an error writing the Following:
"An unhandled exception of type 'System.Exception' occurred in Microsoft.SPOT.Hardware.dll"
I do not know if there's anything wrong with the code!
but if something wrong can someone help me?
#2 nakchak
nakchak
  • 404 posts
  • LocationBristol, UK
Posted 20 July 2012 - 08:07 AM
Hi
Try adding a reference to Microsoft.SPOT.IO
Also you could use the events in the RemovableMedia object to detect insert and eject
i.e.
public static void Main(){
 RemovableMedia.Insert += new InsertEventHandler(RemovableMedia_Insert);
 RemovableMedia.Eject += new EjectEventHandler(RemovableMedia_Eject);
void RemovableMedia_Eject(object sender, MediaEventArgs e) {
 Debug.Print("Ejected");
void RemovableMedia_Insert(object sender, MediaEventArgs e) {
 Debug.Print("Inserted");
Nak.
#3 ash
ash
  • 66 posts
Posted 20 July 2012 - 09:35 AM
i just did this:
            DirectoryInfo dirinfo = new DirectoryInfo(@"\SD\Bin");
            if (dirinfo.Exists)
                GotSDCard = true;
:lol:
#4 nakchak
nakchak
  • 404 posts
Posted 20 July 2012 - 11:41 AM
i just did this:
            if (dirinfo.Exists)
                GotSDCard = true;
:lol:
I would imagine you would get an exception if their is no SD card present, where as using the events is far more reliable (and effcient as no objects are created/garbage collected) way of setting a bool to indicate if a card is present, as the event is triggered by the microswitch on the socket, so even if you were to access the SD card in a binary manner (via SPI or something like that if you have a need for a custom FS/Format) the events would still be raised.
Nak.
#5 BrunoPescarolli
BrunoPescarolli
  • 14 posts
  • LocationBrazil
Posted 22 July 2012 - 07:57 PM
Help me please! I am new to the area
#6 BrunoPescarolli
BrunoPescarolli
  • 14 posts
  • LocationBrazil
Posted 22 July 2012 - 09:33 PM
I ran the code that nakchak posted
using System.Net;
using System.Net.Sockets;
using Microsoft.SPOT.IO;
namespace SdCard
The code is perfect but returns errors:
"An object reference is required for the non-static field, method, or property 'SdCard.Program.RemovableMedia_Insert(object, Microsoft.SPOT.IO.MediaEventArgs)'"
"An object reference is required for the non-static field, method, or property 'SdCard.Program.RemovableMedia_Eject(object, Microsoft.SPOT.IO.MediaEventArgs)'"
Should be small thing wrong in the code.
How to solve?
#7 Stefan
Stefan
    Moderator
  • 1965 posts
Posted 23 July 2012 - 06:13 AM
You should make both methods static in this case:
using System.Net;
namespace SdCard
        static void RemovableMedia_Eject(object sender, MediaEventArgs e)
        static void RemovableMedia_Insert(object sender, MediaEventArgs e)
This is because it's in de main program, which is also set up to be static.
#8 BrunoPescarolli
BrunoPescarolli
  • 14 posts
  • LocationBrazil
Posted 23 July 2012 - 08:35 PM
Hi Stefan the code running OK now! no ERROR's! :D I detect the Sd Card OK? I now have access to it like a removable disk Whether have any link that talks about this?
#9 cSharper
cSharper
  • 13 posts
  • LocationOrlando, FL
Posted 18 August 2015 - 04:14 PM
Hi all,
I know this thread is old, but is there an updated way to perform this exact task?
Right now when I run the sample program given, I get this error:
Inserted
A first chance exception of type 'System.IO.IOException' occurred in Microsoft.SPOT.IO.dll
An unhandled exception of type 'System.IO.IOException' occurred in Microsoft.SPOT.IO.dll
 Uncaught exception
Ejected
Inserted
Inserted
