Essentially new to netduino and all that comes with it, I tried getting a simple webserver deployed. Simple in the respect that all it does is turn the onboard LED on and off when sent requests. However, one major problem, the netduino plus will stop responding occasionally so I cannot deploy to it. I hit the reset button and it... seems to do something, flashes the various lights on it. But that does not fix it as Visual Studio keeps being stuck in the preparing to deploy assemblies phase. if I stop the building of the program I can still edit it, visual studio will work fine but wont deploy. but if I ever try to unplug the netduino plus... my computer will immediately shut off.
Not sure if thats a common issue and non-fatal to computers but it scares me. Anyone know a fix to this? Im probably doing something wrong.
Failure to deploy and system crash
Started by Metalith, Jul 13 2012 07:36 PM
Posted 13 July 2012 - 09:05 PM
Hi Metalith,
Sorry for the driver glitch you're experiencing; this is a bug in the NETMF drivers that affects some computers, particularly when using .NET MF 4.2.
Microsoft has created new drivers (based on WinUSB) which should be entering beta soon.
BTW, welcome to the Netduino community.
Posted 13 July 2012 - 09:17 PM
Netduinos have a 500mA USB fuse on them and ESD protection for USB, to help protect both your Netduino and your PC.Ah that explains it... Its not damaging my computer, is it?
Rebooting or shutting off your PC suddenly is never a particularly good thing. If you are experiencing these issues while waiting for the new drivers, be sure to save data in any open applications from time to time.
Oh, no problem. That's what we're all here for...to help each other be successful building cool projects/products.And thanks by the way.
Posted 29 November 2012 - 05:48 PM
I have this same problem in my application, using a Netduino Plus 2.
Temporary workaround:
Open the Device Manager, then disable the Netduino. After the failure tones, you can unplug and reconnect the Netduino. You'll get those failure tones again, but when you re-enable the Netduino, VS2010 will be able to deploy again. It's a little annoying, but I wonder if it has to do with buggy application code.
In my particular case I think that could be the reason, and it's definitely tied to COM1 somehow. I'm in the process of working on a library that communicates with an external peripheral over RS232, and when my parsing fails, the external device keeps sending data. It seems like in this case, the Netduino freaks out and can no longer be programmed until I reset it with the above steps.
