Web Based IR Remote
#21
Posted 23 July 2012 - 08:40 PM
#22
Posted 08 July 2013 - 02:24 AM
Hello all, Unfortunately, I was unable to finish this project last summer before it became too cool to need it. However, with the return of the heatwave to NYC, I decided to dust of my old code, fix it up, and finish this project! I've replaced the TMP36 with the HIH6130 temperature/humidity sensor, and used a modified version of the HTTPLibrary V3. I've upgraded the web server to allow the addition and removal of passwords though the web interface so I can grant guests access to the control system, as well as adding some watchdogs to restart the system if the server thread hangs. I also have the server cache a few settings on the SD card so that those settings will survive a reboot or power loss. I added a photoresistor taped over the power LED of the AC unit so I could check if it was on and make sure the IR commands were being followed. I've found that the IR commands have somewhere around an 80% success rate, so getting feedback from the photoresistors was necessary to ensure everything went smoothly. I've attached all the code for this project below, although it's not well documented and still pretty crude, so be warned. I've also included all the HTML/JavaScript files.
I also attached a photo of the system all hooked up, though I still need to build an enclosure for the Netduino. Thanks again for all the help, it's nice to finally have this project finished and working great!
IRWebServer.zip 51.05KB 29 downloads
ServerSetup.JPG 149.04KB 25 downloads
- HCB likes this
#23
Posted 10 July 2013 - 12:57 AM
#24
Posted 10 July 2013 - 07:14 PM
Thanks! The non-intrusive feedback was very important to me, as I wanted this system to be portable to other AC units, and I didn't want to risk destroying a relatively expensive AC unit by soldering to the control board. I don't think they would honor my warranty if I did that...
#25
Posted 19 August 2013 - 11:08 PM
Noob question...i apologise in advance!
I've tried to run this from my ND+2 but i don't seem to be able to find a webpage? i've fixed my ip and placed the htdocs onto my SD card. What am i doing wrong?
#26
Posted 11 October 2013 - 03:24 PM
Hello and welcome to the community!
I can't say for sure without more details what you problem is, but my first guess is that you didn't use the right port. So in order for me to get access to my server through the Internet I had to set the server to listen on port 8081 (my ISP seems to block 80 and 8080). You can find that setting in the Program.cs file here:
ServerConfiguration = new Configuration(8081);
You could change this line and replace 8081 with 80, or try entering the IP address of your Netduino into your browser followed by :8081, for instance:
http://192.168.1.7:8081
If that doesn't help, a few more details about your problem would be useful (are you getting an error message in your browser, is the Netduino debugger outputting anything, etc...), and we can try to troubleshoot some more.
Good luck!
