It would make it tons easier if you could enter in SecretLabs.NETMF.Hardware.NetduinoGo.Sockets(0) etc for the sockets.
I'm not sure how to write data out of the ports, and I don't even think you can load registers with it.
There should also be a Hardware.Netduinogo.Cpu.Register namespace so we can load values into registers of the cpu.
Or even Hardware.Netduinogo.cpu.stack.add(int32)
We also need a cpu.io.port and separate netduinogo.io.port(byte) or netduino.io.socket(byte)
How to write to sockets?
Started by iexpress, Jun 25 2012 03:07 AM
1 reply to this topic
Posted 25 June 2012 - 03:07 AM
Posted 25 June 2012 - 10:16 AM
Hi iexpress,
If you want to use the go!bus sockets in override mode (Gadgeteer compatibility mode), you can use their SPI channels using the SPI class. You can also use their UARTs via the SerialPort class and their IOs via the OutputPort/InputPort/InterruptPort/TristatePort classes.
The sockets are designed primarily for virtualized i/o, but we made sure to enable overriden communication for the types of scenarios you're looking for.
