24vdc to 9vdc step down
Posted 15 June 2012 - 06:38 PM
Posted 15 June 2012 - 07:41 PM
Posted 15 June 2012 - 08:07 PM
Posted 15 June 2012 - 09:21 PM
It depends on the amount of power you will need.
If you need only enough for the Netduino card you could use several methods including the ones listed, but if you need more I would sugest that you consider something like Switching Regulator.
The resistors and the linear regulators waste power, the more the voltage difference the more wasted power (in the form of heat). For instance if the regulator or resistor is dropping 18 vdc (leaving 6 vdc for the Netdunio) and you are using 100ma the lost power would be P=IxE or 18 x .1= 1.8 watts. If you use a voltage divider (resistors) and you change the load then the voltage would change also.
With the switching power supply you will have a lot less loss, some can also raise voltage and some are adjustable.
The one that I linked is just one of many, look around and read the reviews and data sheets. In the end pick what will work the best for you.
Chuck
Posted 15 June 2012 - 10:12 PM
Posted 15 June 2012 - 10:21 PM
Bryan which RS232 shield are you using? I have some relays that needs 12 vdc. I use a wall wart with a split pigtail and feed 12vdc to both the Netduino Plus and the relays.Thanks for the responses. I have considered all of these. As mentioned, the voltage divider wastes power, and voltage varies with load. I was hoping to find a "ready-made" solution, perhaps the one Chuck mentioned. I really expected that there was an existing break-out board that I have not yet found, as I thought this was more common than it may actually be. I am powering the Netduino Plus, with an RS232 shield, using both serial and ethernet communication. The only other power requirement that I may add is a Seeed Studio relay shield.
For simplicity's sake, I really considered the voltage divider route, but I would like to avoid the aforementioned issues. I could be persuaded, however...
Posted 15 June 2012 - 11:16 PM
I'm using the CuteDigi RS232 shield.Bryan which RS232 shield are you using? I have some relays that needs 12 vdc. I use a wall wart with a split pigtail and feed 12vdc to both the Netduino Plus and the relays.
My application requires that I mount the N+ project on a conveyor that has an available 24vdc supply bus running the full length of the conveyor, but AC wall power is not readily available. I need to be able to mount the device anywhere along the conveyor where it is needed, and tap into the available bus. In this case, a 24vdc-to-(9-12)vdc conversion is the only sensible solution.
Posted 16 June 2012 - 01:10 AM
Posted 18 June 2012 - 09:15 AM
Posted 22 June 2012 - 01:28 PM
Posted 22 June 2012 - 01:52 PM
It has been a long time since I have worked with the LM317 series IC. It has a different Pin out than the LM78XX / LM79XX series of regulators. The LM317 has adjust, output & input. It requires additional components to operate (potentiometer or resistors, capacitors etc.). Where as the LM7805 has input, ground & output. The LM7805's output is 5vdc, LM7812 = 12vdc etc. Depending on the load and input voltage you may need a heat shink.I'm going to show my ignorance here, but how does an LM317T compare to those mentioned above? I happen to have one of those I've been playing with.
The LM78XX / 78LXX series come in several load capacities and package styles, T-220, TO-92 (like a small transistor) or surface mounts. With proper heat disipation the LM78XX series is good for 1.0 amp, the 78LXX series about 100 milli-amp.
Chuck
Posted 22 June 2012 - 04:24 PM
You can get ready made adjustable modules on ebay for a few $ or a fixed 5v version which you can power the ND directly with on the 5v pin, in my circuit i have 100uF output filter cap and i have a pretty decent DC output i.e. the noise levels are tiny at most in the 1 to 2 mV range.
Nak.
