tpa81 i2c sensor read error with net cable connected
#1 dexmac
dexmac
Posted 03 June 2012 - 01:34 PM
hi to all i'm developing with netduino plus and tpa 81 sensor on i2c. when network cable is disconnect temperatures values are good. If i connect network cable, temperatures are all wrong (not 0 but strange values). i'm using firmware 4.2.0 RC4. can someone help me ? thanks in advance dexmac
dexmac
www.dexmac.com
#2 Coding Smackdown
Coding Smackdown
  • 78 posts
  • LocationLewisville, TX USA
Posted 05 June 2012 - 05:29 AM
One of the forums members did a pretty exhaustive test around ADC noise and that is probably what you are seeing. You can find his write up at http://highfieldtale...se-of-netduino/ Hope this helps.
http://diybrewery.com
#3 henryyao
henryyao
  • 19 posts
Posted 30 December 2012 - 05:29 PM
Hi dexmac
I'm having a similar issue as your case, still I'm stuck there.
I keep getting strange value from tap81 like 7,39,46,14,3,0,0,0,0,0
I'm in a normal temperature environment so I guess the correct result should be like 7,25,23,24,23,23,21,23,21,21, stuff like that.
So did you figure out the reason for that?
thanks.
Henry
