ZigBee without microcontroller
Posted 09 May 2012 - 12:46 PM
Posted 09 May 2012 - 02:11 PM
Hello mate,Hi everyone,
I was wondering if there's a way to use a zigbee transmitter to broadcast N analog inputs directly to a netduino with a wifi receiver without having to use another microcontroller to manage the data sent by the transmitter.
Or at least, if there's a way to use a zigbee transmitter with a netduino mini used as data manager.
Thanks.
As far as I know (I don´t have nor worked with) ZigBee cannot be used alone, it need to be "driven" by someone. It uses a serial interface (also known as UART) to communicate, so a mini will do the service (on pins 11-12)
Hope had helped!
Posted 09 May 2012 - 02:17 PM
Posted 09 May 2012 - 03:13 PM
For example Digi XBee can be configured in so called API mode, which enables the transmitter to sample and send analog and/or digital inputs periodically. You'd need to flash the appropriate firmware, correctly set all the parameters - there are tutorials available on the Internet, but in most cases they need some tweaking to work correctly in a particular scenario, so you should probably refer to the manual first. Important thing to note is that the receiver has to be configured to work in API mode too (i.e. firmware flashed) and then it requires special protocol to be interfaced with a microcontroller (Netduino). There are already .NET Micro Framework libraries for that such as Grommet or MF Toolkit, I am not sure the code works on Netduino - it might need some changes.
Posted 31 May 2012 - 01:34 PM
I'm sorry for the late reply but i didn't get the notification mail so i bumped in this post again 'accidently'...
Anyway,thanks a lot to everyone for replies.
Mh,the Digi XBee solution seems to be what i was looking for,right price and the possibility to read both analog and digital I/O onboard.
Seems that something like this will be able to do the trick (also without using an ad-hoc controller).
But i was wondering (probably that's a stupid question) there's a way to read them using a common router instead of a XBee wifi receiver?
If not,what do i need to receive the data sent by the component above?
Thanks.
Posted 31 May 2012 - 02:42 PM
you need another XBee which receives the data and sends it to a PC or microcontroller.
PC/Microcontroller<---Serial connection--->XBee<---Radio--->XBee
EDIT: Digi offers some more advanced solutions, but I guess this would be overkill (and expensive): Wireless Routers and Gateways
Posted 01 June 2012 - 09:34 AM
Posted 01 June 2012 - 12:31 PM
For the case you didn't notice already: Digi offers 'Series 1' and 'Series 2' modules (and DigiMesh).
It depends on your needs which module is the best for your. XBee Choice
Posted 04 June 2012 - 08:03 AM
Posted 04 June 2012 - 10:07 AM
Posted 04 June 2012 - 11:02 AM
