Prototype module prototyped on a prototype Protomodule
36 replies to this topic
#21 ItsDan
ItsDan
  • 101 posts
Posted 14 May 2012 - 05:48 PM
Fabien I'll make sure Arron pops in and adds some value to the discussion, but I'll address what I can. To program the module today, yes you'd need a separate ST-Link device to connect to the SWIM port, but that won't always be the case. Eventually you'll be able to deploy firmware to modules using the Go mainboard (this isn't something we're working on, people far smarter than myself are working on this). Likewise the 'standard' module firmware is something being developed to help module developers, not a lot of details other than it's meant to standardize the interface from the device pins to the main board (less logic being handled on the stm8 for most modules). If you wanted to route the connectors for the go bus socket and add the supporting capacitors onto a discovery board I'm sure you could come up with a suitable replacement, although at low-volume I'm not sure how great the cost savings would be, at so the main benefit would be the st-link. But if future updates nullify that, we have a more compact package, designed to accomodate a breadboard, power and ground bus, mounting holes on the Go spec, and if people want a no-solder, ready to go device we'd be happy to offer that.
Track the Box
#22 Arron Chapman
Arron Chapman
  • 289 posts
  • LocationOregon, USA
Posted 14 May 2012 - 07:12 PM
@Fabien
The idea here is that if you want to build a module you can use the protomodule (with or without a mini breadboard) to develop and test your idea very rapidly. This obviously is slightly hindered by the lack of Generic firmware.
As far as the "Standard Module Firmware" goes: what specific features will it provide and when will it be released?
For the answer to that you'll have to talk to Chris. The basic idea there, as far as I understand it, is that it will provide a virtualized interface to the I/Os, including the various higher level protocols such as SPI, UART or I2C. This firmware will suit the needs of most modules, allowing for every pin to be controlled directly by the Go. From the standpoint of the protomodule, this would mean that you can add parts to it and be able to write all of your interface code in C# and never have to touch the module's firmware. As I'm sure your aware there are changes coming to the Go!Bus software spec, I wouldn't expect to see the generic virtualized I/O firmware until after then. Around that time, a project will be released which will allow users to flash the firmware on modules via the Go, this will remove the necessity to have an ST programmer, for the users who don't want to use (or can't) the generic firmware.
This however only addresses a small portion of the user base I expect for the protomodule. So far I've not mentioned the person who has a part, and doesn't want to buy a module to replace it, or someone who has a part that none of the module builders has built a module for. Like the protoshield for the traditional Netduinos I don't expect that most of the users will be looking to build modules for sale.
As for the requirements for working with the protomodule, that one is pretty simple.
  • Netduino Go
  • Computer capable of programming the Netduino Go
I'll be the first to admit that at this point in time that isn't true, that to use the protomodule effectively you need a programmer and you'll have to write your own firmware, for an undocumented protocol. Two things about this are true though; First, that is going to change with the addition on the generic firmware. Second, I expect all or at least most of the early adopters to be people who are looking to build modules or who are already building modules.
#23 Fabien Royer
Fabien Royer
  • 406 posts
  • LocationRedmond, WA
Posted 14 May 2012 - 08:12 PM
Dan, Arron,
Thanks for providing additional details.
That means adding another ~$20 to the $20 cost of the ProtoModule, way over the $8 cost of the STM8S.
The detachable board on the STM8S has the necessary decoupling capacitors and features a 16 Mhz quartz for precision frequency counting / generation. Does the ProtoModule include a resonator or a quartz as well? For reference, here is the STM8S, detached from the STLink interface, with a Go! connector soldered to it:
Posted Image
Can you please share a link to that Go!Bus software spec? I have yet to see it.
I have asked Chris and did not get the answers I was seeking. It sounded like you had insights that I did not have.
I've heard this before, starting with the Shield Base... and it sounds like these two solutions will be competing with each other.
It will be interesting to see how these features will fit and perform within the constrained resources available on the STM8...
Flashing module firmware onto a module is one thing, programming / debugging one is another thing altogether that the Go! project to be released will definitely not address.
Thanks for clarifying.
It isn't true until I can run actual bits Posted Image
I believe that you're correct and as one of these people, I don't understand the value proposition at the moment.
Cheers,
-Fabien.
#24 Arron Chapman
Arron Chapman
  • 289 posts
Posted 14 May 2012 - 08:34 PM
If you wanted to you can do like I did, and just buy the STM8s Discovery board and use the top half as a programmer.
...for an undocumented protocol
Stop by chat sometime or add my on skype (unkwntech) and we can discuss it at length.
Resources are not that constrained on the STM8s, at least not from my experience thus far.
Sure, but with the generic firmware the only debugging one should have to do (in most cases) is between the module and the hardware your trying to use. This is no different from working with the Netduino (+/Mini).
#25 Fabien Royer
Fabien Royer
  • 406 posts
Posted 14 May 2012 - 09:14 PM
You've got a Skype contact request pending Posted Image
Generic firmware supporting virtualized I/Os for various peripheral types will challenge the capabilities of the STM8s, especially when using more than one at a time.
Cheers,
-Fabien.
#26 Chris Walker
Posted 14 May 2012 - 10:35 PM
Hi Fabien,
I believe that Arron is talking about the planned standard virtual i/o firmware that's planned for Netduino Go and go!bus. With the initial launch of Netduino Go, we're using a 1.0 draft spec of go!bus (electrical and mechanical only). We're using the Shield Base to work out the Virtual I/O specifics for STM32...and then we'll port these to STM8S.
We're making lots of progress on a few software updates to Netduino Go... Once we feel comfortable with the performance of virtual i/o on the Shield Base, we'll formalize that into a spec. You're welcome to join with us in implementing that for STM8S if you'd like...Netduino is community.
We've had a lot of interest in building modules, so we're giving early guidance and logo approval for module builders who feel comfortable writing their own custom SPI code for modules (like with the Nwazet display module)...understanding that that code will need to be re-integrated into or replaced by the standard i/o firmware in a few months.
We saw how .NET Gadgeteer went from something simple to something sort-of-compatible and overly-complicated in a matter of months, and we're determined to use the go!bus interoperability logo program and virtual i/o to ensure that doesn't happen with the go!bus ecosystem. It's all balance...hopefully we can all come up with the best balance.
You're fairly advanced with software and electrical design, but I think that a lot of users will want to design their own modules (for sale or for personal use). The STM8S-Discovery can be a pretty intimiating thing to look at, so having a simpler starting point to work with (such as ItsDan and Arron's Prototype module) is really valuable.
#27 JonnyBoats
JonnyBoats
  • 155 posts
  • LocationPhillips, ME
Posted 15 May 2012 - 02:51 AM
Fabien, have you done a blog post or writeup on this? This is great information.
Posted Image
#28 Nevyn
Nevyn
  • 1072 posts
  • LocationNorth Yorkshire, UK
Posted 15 May 2012 - 04:58 AM
Arron/Dan, Nice work on the module. Looking forward to getting my hands on one and playing :) Regards, Mark
#29 Fred
Fred
  • 302 posts
  • LocationUK
Posted 15 May 2012 - 10:49 AM
Let's not forget that with a lot of hobby projects it's the journey not the destination that's the important bit. Maybe Aaron and Dan aren't making the protomodule because it fills a gap that other existing tools don't support, but because they want to and are having fun. :)
#30 ItsDan
ItsDan
  • 101 posts
Posted 15 May 2012 - 12:19 PM
Fred, Thanks for the support and I agree with your sentiment. Having never gone through the process of seeing a project like this through from computer design files to physical device to functional demo it's been interesting and a lot of fun (and slightly pricey), and I'm a "learn by doing" type of person. This is also something of a test run, I have some parts scattered on my desk that we're exploring for further modules (some attached to protomodules :P), those should be more useful towards filling the lack of useful modules. But as far as this one, if people find value to it, we're glad to be able to offer it, as Fabien pointed out there are other options too, and I actually recommend the Discovery board. It was easy to use and setup and I use one here to program my protomodules.
I've attached an image of a bare PCB next to the discovery board. Note that the actual prototype area on the discovery is the parts below the routed slots. The part above those slots is the ST Link programmer, which is what I connect to the SWIM connector to program the chip on the protomodule.
Track the Box
#31 JonnyBoats
JonnyBoats
  • 155 posts
Posted 15 May 2012 - 03:33 PM
This sounds like a marrage made in heaven Dan. Using the discovery board as a programmer for the proto module seems like a cheaper and more flexible solution rather than buying a separate programmer. Would you be willing to provide more details on your configuration?
#32 ItsDan
ItsDan
  • 101 posts
Posted 15 May 2012 - 05:35 PM
You mean the configuration for programming? On the Revision C boards (all the ones you've seen pictures of) you simply connect the 4 male jumpers on the Discovery board to 4 specific pins on the protomodule (3.3v, swim, gnd, reset), I forget the pin numbers, but it's not important because on Rev D (the ones we'll actually be shipping) we've added space for a 4 pin header on the board already connected to the right pins so you'll just connect it that way, should be simple.
Track the Box
#33 Fabien Royer
Fabien Royer
  • 406 posts
Posted 15 May 2012 - 08:27 PM
Hi Johnny,
I do have a blog post planned related to this.
Having said that, I'm swamped with other Netduino Go! work right now and I won't be able to write it for some time unfortunately.
Cheers,
-Fabien.
#34 ItsDan
ItsDan
  • 101 posts
Posted 02 June 2012 - 02:29 PM
The production boards and components are all in and assembly has started, so anyone who preordered a protomodule should see theirs shipping sometime next week. Thanks for all the support and we're already using protomodules 'in house' to test out new module ideas. Attached are pictures of the Protomodule along with accessory rail headers and a minibreadboard, as well as my programming setup using the STLink on a discovery board connected to the dedicated SWIM port on the protomodule, much easier than the prototype version that required connecting individual pins.
Track the Box
#35 Chris Walker
Posted 02 June 2012 - 09:20 PM
Very cool, congrats ItsDan and Arron! Gotta go order mine now :) Chris
#36 Nevyn
Nevyn
  • 1072 posts
Posted 21 June 2012 - 08:22 PM
I finally managed to get the postal service to release my delivery from the US and it turns out to be the ProtoModule I ordered a few weeks ago :) Time to take my old prototype circuit apart and move the light sensor over to the ProtoModule: Attached File  ProtomoduleLightSensorLabel.jpg   43.63KB   37 downloads I like the fact that the module allowed me to tidy up the breadboard by removing the STM8 and supporting circuitry and it also gives me a socket to connect the module to the GO! all in one nice package. Arron/Dan - thanks for a nice piece of work. Regards, Mark
#37 Gutworks
Gutworks
  • 363 posts
  • LocationOttawa, Ontario
Posted 21 June 2012 - 08:26 PM
Mark that's one nice and tidy setup you have going there. I'm excited to see what sort of module development will be coming from your workshop.
I just got my ProtoModule today as well, but am now waiting on STMicroelectronics to send me an ST-Link.
Great work!
Cheers,
Steve
