Triggering Thread
#1 KODOZANI
KODOZANI
  • LocationTurkey
Posted 28 April 2012 - 03:37 PM
Hi Netduino Users, I have a problem. I want to get analog input (in my case this is a potentiometer) in a specific period. Like 100 Hz. At the end an infinite loop will be perform. Under that there may be a thread which triggers analog input 100 times in a second. How can I do that ? Thanks for your answer. NOTE: After finishing my project, i will share with you.
#2 Mario Vernari
Posted 28 April 2012 - 04:30 PM
Hello Kodozani.
You can do a dedicate thread running endlessly a loop, but it's an overkill, I think.
I'd use a Timer which is also the most accurate way to perform a certain task.
Try this:
class Program
  private static Timer _clock;
  private static AnalogInput _pot = new AnalogInput(Pins.GPIO_PIN_A0);
    _clock = new Timer(Tick, null, 10, 10);
  private static void Tick(object state)
    int read = _pot.Read();
    // do whatever ...
Note: I written the above code by mind...it could contain some error, but it should be pretty near to a working program.
#3 Nevyn
Nevyn
  • 1070 posts
  • LocationNorth Yorkshire, UK
Posted 29 April 2012 - 06:17 AM
There may also be a problem with timing as threads execute for 20ms at a time on NETMF. If you are interested on how threading works then you can find out more in the article Threads and Thread Priorities in NETMF.
