Daisy Chain of Ic74HC595 can it control a LCD screen.
24 replies to this topic
#1 smarcus3
smarcus3
  • 134 posts
Posted 22 April 2012 - 05:22 PM
I currently have an LCD screen controlled via a single Ic74HC595. However, using the daisy chain function like this so that the same 3 IO ports can do more than just control a single lcd, but maybe an lcd and leds.
[code=auto:0]Ic74HC595Chain ChainOut = new Ic74HC595Chain(SPI_Devices.SPI1, Pins.GPIO_PIN_D9, 2)/code]
The daisy chain wiring is shown HERE
Steve
My Other Hobby: Engineer Turned Baker
#2 Stefan
Stefan
    Moderator
  • 1965 posts
Posted 22 April 2012 - 05:59 PM
Hi smarcus3, It depends on the LCD and it's required speed. Can you specify which LCD?
#3 smarcus3
smarcus3
  • 134 posts
Posted 22 April 2012 - 06:00 PM
Hi smarcus3,
I was hoping you would see this.
Its this one, HERE
Steve
#4 Stefan
Stefan
    Moderator
  • 1965 posts
Posted 22 April 2012 - 06:12 PM
Ahhh... you mean something like this? Cant be done. sorry. Nah, just kidding :) Let me find the source code, I've got it somewhere but not close atm. If you have a few hours?
#5 smarcus3
smarcus3
  • 134 posts
Posted 22 April 2012 - 06:13 PM
Yeah so that one daisy chained 595s can drive 1 lcd and other things. Sure take your time. Thanks for the help in advance.
Steve
#6 smarcus3
smarcus3
  • 134 posts
Posted 22 April 2012 - 06:16 PM
I would love to get it in the same format as other 'interfaces' in the toolbox library such as the 7segment led.
Steve
#7 Stefan
Stefan
    Moderator
  • 1965 posts
Posted 22 April 2012 - 06:20 PM
It will be. I've got the code at home. I'll post it here asap :D
#8 smarcus3
smarcus3
  • 134 posts
Posted 22 April 2012 - 06:21 PM
Awesome!!! I was going to take a stab at doing it, but if it is already done Ill work on something else. Can't wait to see the code. Thanks
Steve
#9 Stefan
Stefan
    Moderator
  • 1965 posts
Posted 23 April 2012 - 06:34 AM
Use the attached file to combine these two projects:
- .NET Micro Framework Toolbox
- μLiquidCrystal
Sample code:
Ic74HC595Chain IcChain = new Ic74HC595Chain(SPI_Devices.SPI1, Pins.GPIO_PIN_D8, 3); // Used Latch pin is digital pin 8, used SPI-bus is bus 1; pins 11, 12, 13
Ic74HC595LcdProvider LcdProvider = new Ic74HC595LcdProvider(IcChain, 2);
Lcd Display = new Lcd(LcdProvider);
Display.Begin(Width, Height);
#10 smarcus3
smarcus3
  • 134 posts
Posted 23 April 2012 - 06:39 AM
Thanks. I assume I wire it up the same as on your site here: https://stefan.co/el...h-bitshift-ics/ I'll try it out tomorrow.
Steve
#11 Stefan
Stefan
    Moderator
  • 1965 posts
Yup, and to the LCD like this:
http://geekswithblog...id_crystal.aspx
#12 smarcus3
smarcus3
  • 134 posts
Posted 23 April 2012 - 06:41 AM
I already got the lcd wired up like that so itll only be re-routing a few wires. Thanks. Ill give you a positive review. Or even 2.
Steve
#13 smarcus3
smarcus3
  • 134 posts
Posted 29 April 2012 - 08:01 PM
I just finnaly got around to testing this and I cannot get the lcd to display anything. Which pins of the IC go to which Pins of the N. I hooked it up like the example but it is not working.
Steve
#14 Stefan
Stefan
    Moderator
  • 1965 posts
Posted 29 April 2012 - 08:03 PM
Is your LCD requiring 3.3V or 5V?
#15 smarcus3
smarcus3
  • 134 posts
Posted 29 April 2012 - 08:04 PM
I believe 5V but it should be receiving that. All I did was stop using the microlcd library functions and used your lines of code instead. The wiring is unchanged. I think it might be miss wired on the N side.
Steve
#16 smarcus3
smarcus3
  • 134 posts
Posted 29 April 2012 - 08:38 PM
Just figured it out. Thanks
Steve
#17 Stefan
Stefan
    Moderator
  • 1965 posts
Posted 29 April 2012 - 08:40 PM
Ok cool, what was the issue if I may ask? :)
#18 smarcus3
smarcus3
  • 134 posts
Posted 29 April 2012 - 08:41 PM
Wired up wrong.
Steve
#19 Stefan
Stefan
    Moderator
  • 1965 posts
Posted 29 April 2012 - 08:51 PM
Wired up wrong.
Ahh happens to me all the time as well :)
Glad you got it running now!
#20 smarcus3
smarcus3
  • 134 posts
Posted 29 April 2012 - 08:53 PM
that it does.
Steve
