Found it and it says:
The boost converter is based on the TPS61200 from TI and has solder jumper selectable 5V and 3.3V output, and an under voltage protection of 2.6V.
That's under the safe voltage of a cell in a LiPo battery pack. I will do some more research on that. Very interesting topic though!
Powering the Netduino Go! with a Lipo
Started by Stefan, Apr 22 2012 10:30 AM
23 replies to this topic
#22
Posted 03 July 2012 - 09:07 PM
Got it.
Following information is per cell:
4.2 volts - Fully charged
3.7 volts - Nominal
3.0 volts - My own safe cutoff, a personal preference - I just want to play safe, specially on radio controlled planes
2.7 volts - Safe cutoff
Anything under 2.7 will damage the LiPo battery pack/cell
3.7 volts - Nominal
#23
Posted 26 July 2012 - 02:20 AM
If I have a LiPo 11.1v 3s 5000mAh battery with 20c discharge rate, I should be able to power the Netduino Go for a long time. I have my own rapid charger for it, so no need for a onboard charger. What are the input limits and recommendation for the Netduino Go? Is it 3.3v to 5v as recommended and 3.3v to 12v as a limit?
If I have to step down to 5v, would it be best to use an external voltage regulator such as http://www.dimension...s/anyvolt-micro
hoquet
#24
Posted 26 July 2012 - 03:26 AM
The Netduino Go needs a 5V regulated input, anything less or over may damaged the board as I understand.
