.NET Micro Framework 4.3 Roadmap
Posted 16 April 2012 - 06:58 PM
COMMITTED: Support latest GCC toolchain
We will provide support for latest GCC toolchain, especially to address Cortex processors. CodePlex issue #1346.
Status and Tentative Schedule
We are already working on some of the above items.
W00t! Should have known this earlier...
- Valkyrie-MT likes this
Posted 16 April 2012 - 07:44 PM
Posted 16 April 2012 - 10:36 PM
I believe that this is a NETMF team + community contribution feature for NETMF 4.3.W00t! Should have known this earlier...
Posted 17 April 2012 - 12:28 AM
Features for the version 4.3 of Micro Framework
Thanks for the Update.
Posted 17 August 2012 - 03:33 PM
Posted 17 August 2012 - 04:58 PM
Due to the various ways that firmware can be compiled, the best place to get info on footprint size is probably here on the forums.I recently moved to 4.2 RTM to take advantage of the reduced networking byte-code size which I read about in a forum post on here somewhere. Where does general information about new microframework footprint sizes come from?
Board manufacturers can include the managed code assemblies for various features in the TinyCLR portion of their firmware, or they can leave these assemblies out. If the assemblies are left out, then they take away room from your application code space when you use them...deployed with your app.
Generally, NETMF 4.2 is bigger than NETMF 4.1. We had left about 24KB of buffer space in the NETMF 4.1 image to allow for expansion...and we're using almost all of that to support the new features.
The end result for your application is that you have the same amount of available codespace as before, gained new features and bugfixes, and end up with more RAM for your application.
Posted 14 May 2013 - 04:55 PM
i have upgrade my netduino plus 1 from 4.1 to 4.2 but now i read that the onewire DS18B20 is not supported in 4.2 is there already an update that correct this problem ?
Ernst
Posted 15 May 2013 - 04:43 PM
Hi Ernst,
Ernst
OneWire is not officially supported on the gen1 boards, but we did make a special 4.1 build with CW2's OneWire support libraries. If you need OneWire support on your board, I would recommend sticking with that custom build with the extra feature.
The gen2 boards have OneWire support built into the core firmware, and lots of extra flash so that we can continue updating them with new firmware releases.
