This app downloads the weather from 2 zipcodes and prints out the location, weather condition, temperature, humidity, sunrise, and sunset.
You can also change the zipcodes to any Yahoo Weather Location Code (worldwide).
To run this app:
1. Set your network settings (static IP address and DNS) using MFDeploy.
2. Change the zipcodes on Program.cs lines 101 and 107.
3. Run!
Disclaimer: Please note that this program runs in a loop over and over... There's some sort of memory leak (I'm guessing in the converted program--but could be the firmware...to be determined) that will cause it to throw an "out of memory" exception after a few minutes.
License: Since the original work was licensed via CC BY-SA, this derivative is also licensed under CC BY-SA. The original copyright notice remains in the source--but as noted, this project was reduced and modified for this sample.
And Elze Kool (the original author), if you read this--we'd love to have you in the Netduino community!
