Serial Communication via USB Step by Step
Posted 20 March 2012 - 04:44 AM
Posted 20 March 2012 - 08:43 AM
Posted 03 April 2012 - 01:20 AM
Glad to hear it worked for you.
I did notice in my alpha software that the SerialDataReceivedEventHandler would not fire occasionally and I think it was related to a timer I had in the software. I have since done away with using timers and have not had any issues since.
I am using a timer in the PC application during the running of the race heat - to look for incoming messages (times) and to update the display. I could try having the SerialDataReceivedEventHandler trigger the updates. Might be more efficient.
Posted 22 April 2012 - 09:02 AM
Thanks for the guide,so,basically what i need is only this (i prefer to order from european resellers) and nothing else?Not an usb to serial cable or other stuff?
Thanks.
Just that board and the Mini USB cable which is different than the Micro USB that comes with the Netduino.
Posted 23 April 2012 - 08:31 AM
Thanks,oh,another thing,what is the effective speed of the COM port used with netduino in this way?
Thanks.
Posted 30 May 2012 - 10:00 PM
Posted 30 May 2012 - 10:39 PM
So I take it you can't use the microUSB port on the netduino for communication with a PC app, only programming with VB? Sorry if it's an obvious question - I'm new to both VB and microcontrollers.
Basically, it cannot be a communication port and a debug port at the same time. You can switch and use serial port as debug and this frees up the microUSB port, but I believe it is limited as to what you can do. Best bet is an FTDI card or FTDI cable. I am using this one from Sparkfun which is mentioned in the first post.
Posted 31 May 2012 - 03:49 PM
Good to know, thanks.
