120v to 3.3v
Posted 18 March 2012 - 01:36 AM
Posted 18 March 2012 - 03:08 PM
Simplest would be to get a standard 110V to 5V regulated wall adapter, like this one:
http://www.sparkfun.com/products/8269
To only have a single network cable you could also use POE (power over ethernet) that can send 5V power through an unused twisted pair of wires within the network cable.
For the latter, you'll need both an injector (to insert 5V into the cable in one end) and an extractor (to get the 5V out on the Netduino side). Here's a complete set for that:
http://www.sparkfun.com/products/10759
To control lightning fixtures, you'll need a 110V relay that can be controlled by the Netduino. You'll also need some kind of motion sensor to detect when your child enters the room. Beware that working with 110V can be very dangerous and potentially lethal. I'd think twice before installing homemade 110V equipment in my house with respect to both my kids and insurance policies in case of a fire due to electrical malfunction.
Posted 18 March 2012 - 11:47 PM
Welcome to the forum!
Thank you for the reply, I have looked into the POE but then i would need to get a POE switch and a poe shield for each implementation, I guess i could just take apart one of those wall outlets... was just hoping to find some instructions or maybe a cheap breakout board that does it already.
Posted 19 March 2012 - 06:32 AM
Posted 19 March 2012 - 08:32 AM
No shields are required, the 5$ cable set I suggested should cover your PoE needs. I'ts not real negotiated PoE (and can't be run through a switch) but it let's you insert and extract just about any voltage into any standard 8-wire TP cable because 10/100 networking only uses 6 wires (3 pairs):...but then i would need to get a POE switch and a poe shield for each implementation, I guess i could just take apart one of those wall outlets... was just hoping to find some instructions or maybe a cheap breakout board that does it already.
I might be misunderstanding something, but why would you need to take a wall outlet apart?...I guess i could just take apart one of those wall outlets
Posted 19 March 2012 - 04:42 PM
Correction, only uses 2 pairs. Orange/Orange White and Green/Green White are used for transmitting and receiving data. A lot of commercial POE systems actually send power over two pairs to achieve higher power transfer. As a telecom contractor, there were many times where I used the Brown/Brown White and Blue/Blue White pairs as either a second Cat 5 cable, a phone line or two, or to bring both DSL lines into the modem that we used for IPTV service. May not be the standard, but the standard doesn't work when you only have one existing Cat 5E and no options for running a new one.
That being said, always be aware of how the jack is wired on any device you are plugging into in the event that that device has the Brown and Blue pairs grounded or otherwise used. Last thing you want to do is short your power supply out! The CAT 5E standard allows for Blue pair to be used as a voice(standard phone), and you may find networking devices passing this through. Some people may see the possibility to use this as a potential power source for your devices while not paying for the electricity if you have a land line, and while this is possible, I would advice against it.
Posted 19 March 2012 - 11:42 PM
