Communicating with Netduino via USB
Posted 24 February 2012 - 05:43 AM
Posted 24 February 2012 - 07:08 AM
I do not believe that it is possible for a PC to send data to the Netduino over USB but it is possible for the Netduino to send data to the PC.Seems like it should be possible, since programs are loaded and debugging happens via the USB cable, but is it possible to communicate with the Netduino via the USB cable? If so, are there examples available?
Omar posted a HID example a while ago.
Hope this helps,
Posted 24 February 2012 - 04:05 PM
Posted 25 February 2012 - 03:09 AM
This is not possible. You can use an FTDI cable or FTDI card and a USB cable to communicate via serial port with the Netduino's software.
Thanks, Dave.
I ordered up an FTDI card from Sparkfun.
I saw on the other thread* where this was being discussed. It looks like you provided code on the Netduino end. Do you know if the code on the PC application side from inxtremo looks correct? Do you have any C# code you could share that shows sending and receiving from PC side?
http://forums.netdui...h__1#entry24068
Posted 25 February 2012 - 03:17 AM
Posted 25 February 2012 - 05:42 AM
Great, thanks!I'll try to post up some of my code soon. Mine is not 100% yet, but I can send/receive basic data.
Posted 27 February 2012 - 05:51 PM
Great, thanks!
Hey jwilson,
I got my bug fixed today and I am now receiving the correct packet back from Netduino. I'll do a bit more testing and post of some of my sample code in a couple hours.
Posted 27 February 2012 - 08:09 PM
On the Netduino Side:
Serial Port Def
// The serial port static SerialPort _port;
Init and open the serial port
// Define the port, "COM1" Netduino digital pins D0(RX), D1(TX) at 115200 Baud _port = new SerialPort("COM1", 115200, Parity.None, 8, StopBits.One); _port.DataReceived += new SerialDataReceivedEventHandler(ReceivedData); _port.Open();
Event to receive data/parse data/do something with data
private void ReceivedData(object sender, SerialDataReceivedEventArgs e) { try { // Get the number of incoming bytes int bytes = _port.BytesToRead; // Create a new temporary store byte[] data = new byte[bytes]; // Read in the bytes _port.Read(data, 0, bytes); // Check to see if this is a new read // if so reset the system and get the // length of the incoming data if (!reading) { reading = true; count = 0; readLength = data[0]; inTray = new byte[readLength + 1]; } // Populate the inTray with the incoming data for (int i = 0; i < bytes; i++) { inTray[count] = data[i]; count++; } // Check to see if we have a full packet ParseRecievedData(); } catch (Exception ex) { writeError(ex); } } private void ParseRecievedData() { try { // Check to see if we have a full packet. If so // reconstruct data as text if (count > readLength) { // Remove the first byte as this is the length indicator // not part of the message byte[] outTray = new byte[inTray.Length - 1]; Array.Copy(inTray, 1, outTray, 0, outTray.Length); // Convert the bytes back into a string string text = new string(Encoding.UTF8.GetChars(outTray)); // Reset the reading state reading = false; // Use our new data to do something DoSomethingWithData(text); } } catch (Exception ex) { writeError(ex); } } private void DoSomethingWithData(string data) { try { // Example somethings switch (data) { case "reboot": Reboot(false); break; default: break; } } catch (Exception ex) { writeError(ex); }
On the Windows App side, the code is the same with the exception of the COM port (configure as needed on your project).
I then use this code to send from Windows --> Netduino or Vice Versa.
// Double check the port is open if (!port.IsOpen) { port.Open(); } // Obtain the length of the data to be sent byte[] count = new byte[1] { Convert.ToByte(output_text.Text.Length) }; // Obtain the data to be sent byte[] outBound = Encoding.UTF8.GetBytes(output_text.Text); // Construct our data packet byte[] data = new byte[outBound.Length + 1]; // Set the first byte to equal the length of the data data[0] = count[0]; // Populate the rest of the packet for (int i = 0; i < outBound.Length; i++) { data[1 + i] = outBound[i]; } // Send the packet to the Netduino port.Write(data, 0, data.Length);
I know the code is just pieces but you should be able to connect the Dots and use the correct name spaces. Best of luck!
Posted 28 February 2012 - 04:55 AM
Posted 28 February 2012 - 08:06 AM
Dave,
This looks good - can't wait for my Sparkfun delivery du jour.
On the Windows App side, how did you declare port?
Thanks!
Windows side serial port is:
// The serial port static System.IO.Ports.SerialPort _port;
The code is the same, with the exception that my FTDI card is on COM6.
Posted 03 March 2012 - 12:14 AM
Posted 03 March 2012 - 01:09 AM
Why not possible? You can deploy and debug your software via UART and use USB to communicate with PC, but you need install 4.2 RC4 firmware and switch deploy/debug to UART via special version of MFDeploy. All this you can find in beta firmware section of forum. But, you need more experience to use this method of communication, and need additional hardware and external power to enable USB connection when Netduino loaded your software.
The point is that you cannot communicate with the software loaded on the Netduino via USB. This is why you need the UART connection. You will also find that you will run into deployment issues and communication issues if you have your software running and listening on the UART while trying to deploy. Everytime I wanted to communicate via UART with my windows app, the Netduino would think I was deploying and would send debug information back instead of my data. The only correct solution was to keep these ports separate.
