Hi.Though I feel like I'm masking symptoms, this seems to correct that particular problem:
private void _SerialPort_LineReceived(string Text) { _DebugPrint('I', Text + "\r\n"); // Did we enter command mode? if (Text == "CMD" && this._Mode == Modes.Idle) { this._Mode = Modes.CommandMode; _DebugPrint('D', "Successfully enterred the command mode"); return; } else { if (Text.IndexOf("CMD") >= 0) { Debug.Print("FOUND CMD IN STRING: " + Text); this._Mode = Modes.CommandMode; _DebugPrint('D', "Pretending to Successfully enterred the command mode"); return; } }
There are couple other issues... I'll post when i have more to say about..
thx
2 issues, first it appeared there was a race condition that sometimes truncated the last string, if you set Mode to idle before setting the _SerialPort_StreamBuffer. Here the code:
private void _SerialPort_DataReceived(object sender, SerialDataReceivedEventArgs e) { if (this._SerialPort.BytesToRead == 0) return; // Reads out the data and converts it to a string byte[] ReadBytes = new byte[this._SerialPort.BytesToRead]; this._SerialPort.Read(ReadBytes, 0, ReadBytes.Length); string ReadBuffer = new string(Tools.Bytes2Chars(ReadBytes)); // While in Streaming mode, we need to handle the data differently if (this._Mode == Modes.StreamingMode) { bool newModeIdle = false; _DebugPrint('I', ReadBuffer); string NewBuffer = this._SerialPort_StreamBuffer + ReadBuffer; // Fixes the "*CLOS*" issue as described below this._SerialPort_EndStreamCheck += ReadBuffer; if (this._SerialPort_EndStreamCheck.Length > this._SocketCloseString.Length) this._SerialPort_EndStreamCheck = this._SerialPort_EndStreamCheck.Substring(this._SerialPort_EndStreamCheck.Length - this._SocketCloseString.Length); // Do we need to leave Streaming Mode? int CheckPos = NewBuffer.IndexOf(this._SocketCloseString); if (CheckPos >= 0) { this._SerialPort_TextBuffer = NewBuffer.Substring(CheckPos + this._SocketCloseString.Length); NewBuffer = NewBuffer.Substring(0, CheckPos); //this._Mode = Modes.Idle; newModeIdle = true; _DebugPrint('D', "1 Left streaming mode"); _DebugPrint('D', NewBuffer); } // The closing string (default: "*CLOS*") is many times sent in multiple packets. // This causes annoying issues of connections not shutting down well. // This fixes that issue, but it's possible the last few bytes of the stream contain something like "*CL" or something. else if (_SerialPort_EndStreamCheck == this._SocketCloseString) { //this._Mode = Modes.Idle; newModeIdle = true; _DebugPrint('D', "2 Left streaming mode"); NewBuffer = ""; } this._SerialPort_StreamBuffer = NewBuffer; if (newModeIdle) this._Mode = Modes.Idle; return; }The other thing is just a nicety to remove extraneous *CLOS from the last string (assuming that's not really part of the message).
In HTTP_Client
private HTTP_Response _DoRequest(string RequestData) { // Opens the connection this._Socket.Connect(); // Sends out the request this._Socket.Send(RequestData); // Fetches the returned data string ResponseData = ""; string tmp = ""; while (this._Socket.IsConnected || this._Socket.BytesAvailable > 0) { tmp = this._Socket.Receive(); if (tmp.IndexOf("HTTP/1.1 200 OK") >= 0) { Debug.Print("found OK HEADER at " + tmp.IndexOf("HTTP/1.1 200 OK") + ", resetting input string"); ResponseData = tmp; } else ResponseData += tmp; } // Closes the connection this._Socket.Close(); Debug.Print("RESPONSE: " + ResponseData[ResponseData.Length-1]); string ending = ResponseData.Substring(ResponseData.Length-5); string foo = ending.Substring(1, 4); string foo2 = ending.Substring(2, 3); string foo3 = ending.Substring(3, 2); if (ending == "*CLOS") ResponseData = ResponseData.Substring(0, ResponseData.Length - 5); else if (ending.Substring(1, 4) == "*CLO") ResponseData = ResponseData.Substring(0, ResponseData.Length - 4); else if (ending.Substring(2, 3) == "*CL") ResponseData = ResponseData.Substring(0, ResponseData.Length - 3); else if (ending.Substring(3, 2) == "*C") ResponseData = ResponseData.Substring(0, ResponseData.Length - 2); else if (ending.Substring(4, 1) == "*") ResponseData = ResponseData.Substring(0, ResponseData.Length - 1); // Parses the response data HTTP_Response RetVal = new HTTP_Response(ResponseData); // Parses cookies and such this._ParseHeaders(RetVal.GetAllHeaders()); return RetVal; }looks OK now, but cursory checks.. will do more checking
Fritz
Edited by Stefan, 23 June 2012 - 08:09 AM.
Added [code] tags
