Thanks, sorry for the delay, just got back from a week's vacation in France and Italy.
I would love to have a logo of a "Frankencat" and started thinking in line with your suggestion. I'm not much of a router but still considering to maybe integrate the amplifier on the same board, I mean it's kind of scares now plus there's two sides to play with.
Could be there's not much room for a logo then even if I go up to 100x80mm which is the limit of the free version of Eagle.
What you think?
I guess it wouldn't be good to make the board size bigger just to fit a logo, but maybe just fit whatever you can.
Also I think you should watch the separation of the power stage and the preamp stage, to make sure you don't get inadvertant feedback and hum.
It's been a while since I considered these problems, and sometimes they are not really problems at all.
I am just mentioning the following as a possibility, it is a bit of extra cost and complication.
I think what proved to be the best strategy for noise immunity was to connect the power and common as a star, back to the main power section, and pass the analogue signals around as balanced signals.
Balanced signals are balanced around the common voltage rail.
eg Unbalanced
wire 1. common 0 volts
wire 2 signal 1 sin(wt) volts.
Balanced
wire 1. common 0.5 sin(wt) volts.
wire 2 signal - 0.5 sin(wt) volts.
in either case the signal level is the same but the balanced system has more noise immunity.
I don't think you really need to go this path, but I am sure that most high end equipment uses this type of interconnection whenver possible, between boards and between devices.
