Segmented LED Displays
Posted 19 September 2010 - 11:31 AM
Posted 19 September 2010 - 11:35 AM
Posted 19 September 2010 - 04:15 PM
The correct answer is yes, you need shift registers or a 7-segment display driver and probably a few transistors to help with the current load.I think I'd have to use "shift registers" to make it work? Am I correct?
However... depending how many "digit"s you're trying to control, there may have enough pins on the Netduino.
Take a look the fourth post on this thread. It was an experiment I did a while ago on the Arduino. Multiplexing is cool.
http://www.arduino.c...um=1265669651/0
Posted 19 September 2010 - 04:52 PM
Please note you can easily chain the shift registers (e.g. for 74x595 connect serial output Q7' to the next IC's serial input), so you need only three pins to control large number of individual LEDs (or LED segments): serial data input of the first register, clock and latch wired together for all the registers. For multiple digits, another register can be used to multiplex the common electrode (depending on display type it is either anode or cathode).However... depending how many "digit"s you're trying to control, there may have enough pins on the Netduino.
Posted 19 September 2010 - 05:20 PM
Posted 19 September 2010 - 06:04 PM
As far as enough pins... the Netduino doesn't have enough. I'd need 18 pins I think (17 segment Alphanumeric display, with a 2nd display, so 18 pins?)
Quick note... Netduino has 20 digital (the 14 dedicated digital pins--plus the 6 analog/digital pins). The first four "analog" pins (A0-A3) only drive 2mA however.
Posted 19 September 2010 - 06:10 PM
You can use 74HC595 serial to parallel shift register. As I wrote above, you need only three pins to control such a register, for 17 segment LED display I would use two chained registers (16 segments) and then a separate pin (with a transistor) to control the 17th segment (the dot, if used at all?). It should be also possible to drive the display with only one register, by multiplexing two 8-segment groups.Ok... to shift registers... does that require another chip to use? I've seen some at SparkFun and such.
Posted 19 September 2010 - 06:14 PM
Posted 19 September 2010 - 06:35 PM
It would help to get a bit more details about the part:It contains a 16 segment "alphanumeric" display.
- Does it have any part number? If not,
- Do you know the common electrode? Anode or cathode?
- Do you know forward voltage of a single segment? If not, what is the segment color?
Posted 19 September 2010 - 08:07 PM
All I know right now... is that I scavenged these from a deep-fryer controller. Haven't found any part #'s yet.
I'll pull it out later and look again... see if I can find some info for you.
Posted 20 September 2010 - 05:56 AM
I should be able to help you with connecting the LED display to Nedtuino and perhaps the controlling algorithm for the register, multiplexing etc. I am asking for details, because they may significantly affect selection of the components: for example, if the display is big, it can have a segment composed of multiple LEDs, then you'd probably need a power version of the shift register that supports higher voltage or current; the common electrode determines what kind of transistor (NPN or PNP) can be used to switch it; and forward voltage has to be known to calculate the current limiting resistor (the register itself has some voltage drop, which should be included in the formula etc.). The LED voltage can be guessed from its color, see the Colors and materials table.I'll pull it out later and look again... see if I can find some info for you.
Posted 25 September 2010 - 03:22 PM
Posted 26 September 2010 - 05:32 PM
Posted 26 September 2010 - 07:04 PM
Hi Eric,
Maybe this example will help you get started:
http://geekswithblog...nking_leds.aspx
It shows how to use a shift register to talk with two 7 segment LED modules.
Thanks Szymon! I'll pick up a couple of shift registers this week (I don't have any in my collection of parts). I'm hoping the Netduino Plus shows up at MakerShed soon... I'll order everything from them.
