Waterproof temperature sensor?
Posted 08 February 2012 - 05:09 AM
Posted 08 February 2012 - 06:06 AM
http://www.practical...perature-sensor
There's another one out there which showed putting one in a bit of copper pipe, but copper is a no-no in aquariums if you have any shrimp or snails.
Pete
Posted 08 February 2012 - 07:33 AM
If you are willing to look at encasing the sensor then have you heard of Polymorph? Melts at 60 C but then I think your fish would have problems if you start getting near this temperature.I never really considered taking a regular temp sensor and putting it in silicone, but this seems somewhat promising
BTW - not tried this, just wondering if it would help.
Edited by Nevyn, 08 February 2012 - 07:35 AM.
Posted 08 February 2012 - 08:03 AM
Posted 08 February 2012 - 08:16 AM
I don't know how much is your budget, but I'd suggest a PT-100 probe, stainless-steel shielded, along with a good analog adapter (ADC biult-in as plus). I guess that stainless-steel should haven't any problem with any kind of fish/plant. (Let me ask to my wife...)
We're using two kinds of temperature probes for heavy dusty, and hard climate environment systems: KTY81 and PT-100. The first is much cheaper, less precise (-/+ 1'C), and not so reliable. Many customers switched briefly from KTY81 to PT-100: pricey, but you forget them.
We have some solution, but it's not tailored for home/hobbistic purpose, thus maybe will be not so cheap. Anyway, just PM me in case.
The tip about PT-100 is also about the precision: it's 0.1 'C, which is pretty important for some kind of fish.
Reptiles: I know that the turtle eggs kept at 26-27 'C yield mostly males, instead 28-29 'C yield mostly females.
Also, when using a so precise probe, the Netduino ADC is not recommended. Instead, should be used a calibrated analog converter, tailored for PT-100, and maybe exchanging data via SPI/I2C/UART.
Hope it helps.
EDIT: Just asked my wife. Stainless-steel is surely better other than other common metals, especially when the water is salted. However, no material is "perfect": even plastic is toxic!
Edited by Mario Vernari, 08 February 2012 - 08:57 AM.
Posted 08 February 2012 - 09:01 AM
How about waterproof DS18B20 (Adafruit, Sparkfun)? I guess TO-92 package is not that hard to seal, perhaps it would be enough to wrap the leads with heat shrinks or cover with silicone...Any recommendations on a waterproof temperature sensor I can use with Netduino?
Posted 08 February 2012 - 10:52 AM
Posted 08 February 2012 - 11:20 AM
Both chromel and alumel should be water resistant.
The main problem would not be the life time of the probe, but the fishes!
Chrome and Nickel are highly polluting, Aluminum less, but depends of the acidity of the water (e.g. salted or not)
Posted 08 February 2012 - 12:38 PM
Many years ago at school I used an LM35 and potted it in two part adhesive to the end of a glass tube. The tube was a similar diameter to the LM35 package, so the wires slipped inside and were kept away from any liquid, but the plastic body of the probe was outside the glass. I don't now how inert the cured adhesive is - it might not be good for fish.
I should mention that I suggested using the LM35 to < cobolstinks > in this thread http://forums.netdui...rature-project/ but that he had to abandon the LM35 in favour of a one wire device. The issue was too much noise on the analogue signal probably due to long length cables back to the Netduino.
< Coding Smackdown > was also working on a temperature monitoring project, in this case for a home brewery http://forums.netdui...erature-logger. He must have sealed his sensors in some way.
Perhaps you could combine the fish tank and brewery - fishy beer!
Hope this helps.- Paul
Posted 08 February 2012 - 04:18 PM
Posted 08 February 2012 - 07:18 PM
Posted 08 February 2012 - 08:29 PM
Maybe it'd be a good idea to heat the tube to expel excess moisture in the air and possibly draw a bit of a vacuum when you seal it. That will further reduce the air volume and help eliminate condensation from affecting your board and causing corrosion.
Alternatively maybe you could drop in a desiccant packet from a pill bottle if you don't want to heat blast the tube. Either way, I think it's a good idea to remove as much moisture from the sensor area before you seal it.
I ended up making one using a LM35DZ and a papermate flexgrip pen. I connected everything up, slid the sensor into the pen and filled the whole pen up with silicone. I made sure the sensor was exposed to air, but nothing else, and it works like a charm. I'm using it to monitor my aquarium temperature.
Posted 10 February 2012 - 04:23 AM
Posted 10 February 2012 - 07:17 AM
Posted 11 February 2012 - 07:16 AM
http://www.brewersha...rature-Sensors/
Edit: They're stainless steel. They even offer the probe ends separately. They're made for the Dallas ds18b20.
Pete
Posted 11 February 2012 - 07:39 AM
Stumbled across these. I had never considered looking for brewer info. These are 1-wire Dallas-sensor based temperatore sensors
Pete
I'm wondering whether my infrared library could solve even the one-wire protocol interfacing. Unfortunately I don't have any 1-wire chip now.
Posted 11 February 2012 - 03:25 PM
Pete
Is Stainless ok in Fresh Water? I can't do it in my reef tank, which is why the Silicone DIY worked so well. That and I'd rather not spend an arm and a leg for a temp probe (that's for the pH probes.....)
#19
Posted 11 February 2012 - 04:13 PM
#20
Posted 11 February 2012 - 04:25 PM
- Arron Chapman and ErikN like this
