6 degrees of freedom
Posted 31 January 2012 - 10:11 PM
Posted 01 February 2012 - 10:08 AM
Posted 02 February 2012 - 06:43 AM
The example mentioned in the other thread contained a ADXL345 as the set of accelerometers. I succesfully connected one of those on its own to my Netduino, using information and code from https://www.loveelec...how-to-use-them. My project did not do anything useful, it just indicated accelerations by means of a 3 rows of leds:), I am very much a beginner in the field of electronics. So I do not have the final answer, but I hope it serves as a start.
With best regards, Peter
Posted 02 February 2012 - 08:20 AM
Posted 02 February 2012 - 09:05 AM
Posted 02 February 2012 - 03:17 PM
Thanks for the input everyone.Hi Jacques, unfortunately I don't own one of those, just de ADXL345. I sincerely do hope you get some more useful answers then mine. But if not, from the info at Sparkfun (it is basically an ADXL345 accelerometer + ITG3200 gyro on the same breakout-board), it appears like you could start by using the info on the Loveelectronics site and get at least the accelerometer part working with your Netduino plus. From there hopefully you can extend their code to include the gyro output.
I went ahead and bout this today (the one with ADXL345 and ITG3200) along with an LLC.
I found that loveelectronics page too and was hoping I could start with that and worry about the gyro later.
I will let you guys know how it goes with regards to the ADXL345.
p.s. This is coming from a guy who is about to solder for the first time
EDIT: The place I bought it from sent me this link to show how to wire it:
Posted 02 February 2012 - 05:00 PM
Posted 03 February 2012 - 12:01 AM
namespace accelerometer
// Define our accelerometer inputs
static AnalogInput accX;
static AnalogInput accY;
static AnalogInput accZ;
// Create the Inputs
accX = new AnalogInput(Pins.GPIO_PIN_A0);
accY = new AnalogInput(Pins.GPIO_PIN_A1);
accZ = new AnalogInput(Pins.GPIO_PIN_A2);
Debug.Print("accX: " + accX.Read().ToString());
Debug.Print("accY: " + accY.Read().ToString());
Debug.Print("accZ: " + accZ.Read().ToString());
- martinlee556 likes this
Posted 03 February 2012 - 01:37 PM
Hmmm, I wired mine up like in the picture and can get no response from it.Hi,
Just curious, but I'm not sure why you'd need the logic level convertor. (neither for Arduino?)
Anyone have insight into this?
Can't you just skip the 5v input and run the 2 data lines straight in to the AIO's?
Not a huge deal - $1.95, but the part is listed as "2.7 to 5.2V supply range"
Dan
Surely someone here can recommend the best way to wire the 6DOF? I can't seem to find any info on the net
EDIT: Ok, I think it's actually working. I run this:
I2CDevice adxl = new I2CDevice(new I2CDevice.Configuration(0x53, 100)); byte[] devid = new byte[1] { 1 }; I2CDevice.I2CWriteTransaction write = I2CDevice.CreateWriteTransaction(new byte[] { 0 }); I2CDevice.I2CReadTransaction read = I2CDevice.CreateReadTransaction(devid); I2CDevice.I2CTransaction[] actions = new I2CDevice.I2CTransaction[] { write, read }; adxl.Execute(actions, 1000); Debug.Print(devid[0].ToString());And get a result of 192. I have absolutely no idea what the significance of that is though
EDIT2: Ok, from the data sheet(pg 15) that 192 is:
The DEVID register holds a fixed device ID code of 0xE5 (345 octal).
EDIT3: YAY! I have it working! The range is a bit weird, but will read through the datasheet some more.
http://www.youtube.com/watch?v=hE4trZpbVEc
EDIT4: Now have it completely working, and giving me proper signed degrees via some very basic math. Guess it's onto the gyro next.
Posted 07 October 2012 - 05:34 PM
