Bug in system.net.sockets
#1 rhamer
rhamer
  • 29 posts
  • LocationMelbourne Australia
Posted 24 January 2012 - 10:28 PM
I have just encountered some strange behaviour with the socket.send() method in V4.2
using the following code, I get an exception thrown on every ninth byte.
    Public Function SendData(Data As Byte) As Boolean
        Dim ret As Boolean
        Dim DataByteArray() = {Data}
        Try
            clientSocket.Send(DataByteArray)
            ret = True
        Catch ex As Exception
            ret = False
        End Try
        Return ret
    End Function
This happens reliably every time.
The other odd thing is when I look at the data using wireshark, the data in the packets is always as follows.
1 data byte
7 data bytes
(exception thrown byte never sent)
1 data byte
7 data bytes
this pattern continues until there is no more data to send.
If I catch the false return from the above method and just call the method again with the same byte, it works, so it is not the contents of the byte that is the problem (it is also different with every ninth byte not being the same data anyway)
Recalling the same method after an exception fixes the problem in as much as the byte is eventually sent, but it slows down the execution dramatically as you can imagine, and is not an acceptable workaround.
Can anybody think of something I might be doing wrong?
Regards
Rohan
#2 Valkyrie-MT
Valkyrie-MT
  • 315 posts
  • LocationIndiana, USA
Posted 25 January 2012 - 01:00 AM
Just to clarify, you are sending a single byte with each call of "clientSocket.Send" ? -Valkyrie-MT
#3 rhamer
rhamer
  • 29 posts
Posted 25 January 2012 - 01:56 AM
-Valkyrie-MT
Yes that is correct.
Regards
Rohan
#4 rhamer
rhamer
  • 29 posts
Posted 25 January 2012 - 04:05 AM
Further to my example above, I can confirm the following code example does not have the problem.
    Public Function SendDataArray(Data() As Byte) As Boolean
        Dim ret As Boolean
        Try
            clientSocket.Send(Data)
            ret = True
            ret = False
        End Try
        Return ret
    End Function
The difference here is I'm passing a byte array into the method (instead of just a byte) which should make no difference at all, except the array contains more than 1 byte.
I can repeatedly call this method with no exceptions being generated.
Regards
Rohan
