Hello
It's my first project with Netduino.
Really when i start to think about develop with VBNET i was very happy.
But now, i am thinking : that is not than good like sound...
my last problem is ...
i'm trying to convert a single char to integer with :
Dim words As String() = linea.Split(","c)
Dim HoraInicio As New System.DateTime(1900, 1, 1,ctype(words(0),integer), ctype(words(1),integer), 0)
i was trying too with
a=cint(words(0))
and return an error.....
what am i doing bad??
is too dificoult convert a single string to integer??
sorry for my english.
thanks in advance.
Hi rlcobos and welcome to the boards!
Could you post a full code, perhaps something would be wrong with the input value.
I normally use int.Parse(stringvalue) by the way.
thanks for your quickly reply....
my code is...
'voy separando las lineas, para procesarlas.
Try
' Create an instance of StreamReader to read from a file.
Using sr As StreamReader = New StreamReader("\SD\datos.txt")
Dim linea As String
' Read and display the lines from the file until the end
' of the file is reached.
Do
linea = sr.ReadLine()
Debug.Print(func.Valor(words(0).ToString))
Dim HoraInicio As New System.DateTime(1900, 1, 1, func.Valor(words(0).ToString), func.Valor(words(1).ToString), 0)
Dim HoraFin As New System.DateTime(1900, 1, 1, func.Valor(words(2).ToString), func.Valor(words(3).ToString), 0)
Dim Dia As Integer = func.Valor(words(4).ToString)
Insertar(fCol, HoraInicio, HoraFin, Dia)
Loop Until linea Is Nothing
sr.Close()
End Using
Catch E As Exception
' Let the user know what went wrong.
Debug.Print("The file could not be read:")
Debug.Print(E.Message)
End Try
I have make a new function for convert the string to value
is func.valor....
the original code was...
Dim HoraInicio As New System.DateTime(1900, 1, 1, cInt(words(0).ToString), cInt(words(1).ToString), 0)
and i have try too with...
Dim HoraInicio As New System.DateTime(1900, 1, 1, ctype(words(0).ToString,integer), ctype(words(1).ToString,integer), 0)
thanks, I supouse , i will ask a lot of question from today......
thanks
bye
Dim Hours As String = "5"
Dim Minutes As String = "23"
Dim MyDate As New DateTime(1900, 1, 1, CInt(Hours), CInt(Minutes), 0)
Debug.Print(MyDate.ToString)
This code works fine for me and produces the expected result: 01/01/1900 05:23:00
So what are the values of words(0) and words(1) and what is the error?
At the first moment, thanks for your time....
I have tryed with
try
Dim a As String = "10"
Dim h As New System.DateTime(1900, 1, 1, CInt(a), CInt(a), 0)
catch e as exception
Debug.print e.message
end try
and i have the next in debug...
Exception was thrown: System.NotImplementedException
I work with
DeviceInfo:
HAL build info: 4.2.0.0, Netduino Plus (v4.2.0.0 RC3) by Secret Labs LLC
OEM Product codes (vendor, model, SKU): 34, 177, 4097
Serial Numbers (module, system):
00000000000000000000000000000000
0000000000000000
Solution Build Info: 4.2.0.0, Netduino Plus (v4.2.0.0 RC3) by Secret Labs LLC
AppDomains:
Assemblies:
mscorlib,4.2.0.0
Microsoft.SPOT.Native,4.2.0.0
Microsoft.SPOT.Hardware,4.2.0.0
Microsoft.SPOT.Net,4.2.0.0
System,4.2.0.0
Microsoft.SPOT.Hardware.SerialPort,4.2.0.0
Microsoft.SPOT.IO,4.2.0.0
System.IO,4.2.0.0
Microsoft.SPOT.Hardware.Usb,4.2.0.0
Microsoft.SPOT.Hardware.PWM,4.2.0.0
SecretLabs.NETMF.Hardware,4.2.0.0
SecretLabs.NETMF.Diagnostics,4.2.0.0
Without SD Card,1.0.0.0
Microsoft.VisualBasic,1.0.0.0
classFecha,1.0.0.0
I have solved this problem with an function in c#, but may be good i can found a better solution.s
thanks in advance.
