I have been debugging my Netduino Minis using the TTL UART (COM1 on pins 11 and 12). I followed the instructions at Getting Started with a Netduino Mini by Fabien Royer to set them up. However, now I want to switch back to debugging over RS-232 (COM2 on pins 1-4). I can't seem to find a way to do this. Do I need to flash the devices to make the switch?
Switch Debugging Port Back to RS232
Started by Kevin Hazzard, Dec 31 2011 03:03 AM
Posted 31 December 2011 - 03:03 AM
Posted 31 December 2011 - 01:45 PM
Hi Kevin,Do I need to flash the devices to make the switch?
You indeed need to flash the RS232 firmware to the Netduino Mini to accomplish that as far as I know.
Posted 31 December 2011 - 02:52 PM
Had the exact same problem last night.. but found the answer here
http://forums.netdui...p?showtopic=945
This version of MFDeploy lets you switch ports (although is seems like COM1/2 is switched around - but I might have been tired).
- Arron Chapman and Kevin Hazzard like this
Posted 31 December 2011 - 09:11 PM
That did it, Claus! Thank you. But as you said, COM1/COM2 are backwards in the application. I selected COM1 to switch the deployment transport to the RS-232 UART, which is COM2.
Kevin
Kevin
