Gyroscope Module L3G4200D help
#1 jsnmc
jsnmc
  • 7 posts
Posted 22 December 2011 - 07:22 AM
Hello, I have been following for a while, but never posted - great site btw!
This is the first time that I have attempted I2C. I am trying to get a Parallax gyro ( L3G4200D ) working with my Netduino and I don't seem to be getting good numbers for the x/y/z ( I get initial numbers and they never change with movement, nor do they look correct).
I lifted some of the I2C code from LoveElectronics.Sensors.Accelerometers. I tried to use this: "Arduino example with the L3G4200D" and this: "Parallax kickstart"as other points of reference.
I have posted a very simple version of my code below. I don't feel comfortable with what I am passing to the Configuration constructor, but I am not sure.
Any help here would be appreciated.
using LoveElectronics.Sensors.Accelerometers;
using LoveElectronics.Resources;
namespace NetduinoApplication1
    public class gyroTest : I2CDevice
        private int m_Timeout = 1000;
        // int Addr = 105; // 0x69 Adress for L3G4200D
        private ushort m_Address;
        public gyroTest()
            : this(0x69)
        public gyroTest(ushort address)
            : base(new Configuration(address, 100))
            m_Address = address;
        public byte[] Read(byte memoryAddress, int responseLength = 1)
            var buffer = new byte[responseLength];
            I2CDevice.I2CTransaction[] transaction;
            transaction = new I2CDevice.I2CTransaction[]
                I2CDevice.CreateWriteTransaction(new byte[] { memoryAddress }),
                I2CDevice.CreateReadTransaction(buffer)
            int result = Execute(transaction, m_Timeout);
            return buffer;
        public void Write(byte memoryAddress, byte value)
                I2CDevice.CreateWriteTransaction(new byte[] { memoryAddress, value })
            gyroTest t = new gyroTest();
            t.Write(0x1F, 0x20);   // Turn on XYZ axes
            t.Write(0x08, 0x22);   // control
            t.Write(0x80, 0x23);   // Scale to 500 deg/sec
            Thread.Sleep(1000);
            int timerPeriod = 50;
            Timer timer = new Timer(delegate(object o)
                byte[] MSBx = t.Read(0x29, 1);
                byte[] LSBx = t.Read(0x28, 1);
                int x = ((MSBx[0] << 8) | LSBx[0]);
                byte[] MSBy = t.Read(0x2B, 1);
                byte[] LSBy = t.Read(0x2A, 1);
                int y = ((MSBy[0] << 8) | LSBy[0]);
                byte[] MSBz = t.Read(0x2D, 1);
                byte[] LSBz = t.Read(0x2C, 1);
                int z = ((MSBz[0] << 8) | LSBz[0]);
                Debug.Print("X: " + x + " Y: " + y + " Z: " + z);
            }, null, 0, timerPeriod);
            // Make sure the device runs the timer and doesnt end execution.
#2 gbreder
gbreder
  • 53 posts
  • LocationGermany
Posted 02 January 2012 - 05:29 PM
Hi jsnmc,
when I look into your code I see a write transaction immediately followed by a read transaction. I guess the write transaction is used to set some parameters in the gyro and the read transaction is the real operation to get some values from the sensor. Such a contruct needs IMHO an I2C repeated-start-condition. The I2C repeated-start-condition is only supported on Netduino Firmware 4.1.1 and 4.2.x. The RTM firmware 4.0.x doesn't support it.
Please look in the specs of your gyro sensor if two transaction without stop-condition between them are needed. If so update to 4.2 RC3 Firmware. Please erase your netduino completly and reflash it with help of the SAMBA tool. Otherwise it will be really unstable.
Here are two link to successfully update the firmware on the first try: :)
Erase Netduino
Update firmware
And here is the page how to use repeated start bit: :)
How to code repeated start bit
Regards
Guido
#3 StanDeMan
StanDeMan
  • 14 posts
Posted 03 January 2012 - 08:45 PM
Hi jsnmc, swap address and value to this: t.Write(0x20, 0x0F); // Turn on XYZ axes t.Write(0x22, 0x08); // control t.Write(0x23, 0x30); // Scale to 2000 deg/sec Hopefully this helps. Let me know, please. :) Regards, StanDeMan
#4 Stefan W.
Stefan W.
  • 153 posts
Posted 04 January 2012 - 03:58 PM
Judging from the arduino sample code, it isn't needed.
I believe that no discovery of fact, however trivial, can be wholly useless to the race, and that no trumpeting of falsehood, however virtuous in intent, can be anything but vicious.
-- H.L. Mencken, "What I Believe"
#5 jsnmc
jsnmc
  • 7 posts
Posted 07 January 2012 - 03:13 AM
StanDeMan - that fixed it. Oh boy rookie mistake :huh: . Thanks for the good eyes!
jsnmc
