Looking for developers to help in free and opensource project
Posted 11 December 2011 - 10:29 AM
Posted 17 December 2011 - 10:23 AM
Posted 17 December 2011 - 02:29 PM
I am looking for some volunteers to help me with Coding of the Project. I am doing the coding in Visual Basic 2010 and currently using MS Access 2007 as the Database.
Sorry, can't spare the time but I would offer a suggestion about your data storage. Do not use MS Access MDB for any new project. Jet has been depreciated by MS (Microsoft.Jet.OLEDB.4.0 in Windows 7 64 bit is not available). If this is an application for general use, you will find W7 64bit to be a common platform you will need to support.
The recommended data store technology for single user desktop databases is Microsoft SQL Server Compact Edition. The new version 4 is available, and with VS2010 SP1 you get tools to create and manage data files and IDE integration. SQLCE is embedded so no extra runtime or database server installs needed, you just add the SQLCE dll's to your installer. I've used it and it works well! See here:
SQL Compact Home Page
SQL Compact Blog
Good Luck!
Mike
Posted 20 December 2011 - 02:32 PM
SQL Compact Blog
Good Luck!
Mike
We are currently considering the use of this database and we will probably be using this one instead of Access.
Posted 26 February 2012 - 09:02 PM
Posted 05 June 2012 - 06:17 PM
Hi there,
I would definitely support the use of SQL CE as a start as it also scales well to full SQL server and/or make collaboration/syncing with full SQL easier.
N-Tier-Application design (google - loads of examples) is something worth getting to grips with as part of the planning stage before moving much further forward. N-Tier design and implementation will make many aspects easier and more flexible as the App develops.
It provides clear demarcation and can allow for rapid redevelopment of a whole layer minimising the chances of overlooking something. It would also allow you to build multiple DAL's (Data Access Layers) which could deal with connecting to different Data Stores etc, or redesign PL's (Presentation layers) without worrying about destabilising the underlying code.
Is SQL CE fully supported by the Netduino MF?
Posted 05 June 2012 - 09:00 PM
No, x86/x64 only.
Thanks EMG, now that makes me curious, do you know of any alike SQL database available for the Netduino MF?
I have used EffiProz for a Silverlight project that is C# native and I used it to store data from a remote SQL server database into the Isolated Storage (A special folder in the C:\ Hard Drive).
Interesting topic.
