^ Exponent Operator doesn't exists in VB?
6 replies to this topic
#1 Netduinerd
Netduinerd
  • 10 posts
  • LocationVenice, Italy
Posted 03 December 2011 - 10:51 PM
Hi all, I'm looking for the Visual basic Exponent Operator "^" or its replacement without success....any suggestion? Thanx in advance Netduinerd
#2 baxter
baxter
  • 415 posts
Posted 04 December 2011 - 11:04 PM
Hi Netduinerd,
For standard integer exponentiation,
Public Function pow(ByVal a As Integer, ByVal b As Integer) As Integer
        'the bth power of a, where a is an integer, b a positive integer.
        Dim x, y, z As Integer
        x = a
        y = b
        z = 1
        Do While (y > 0)
            Do While (y Mod 2 = 0)
                y = y \ 2
                x = (x * x)
            Loop
            y = y - 1
            z = z * x
        Loop
        Return z
    End Function
See the following for floating point exponentiation,
http://stackoverflow...-power-function
and for the necessary square root, from Mario Vernari a contributer to the forum,
http://forums.netdui...h__1#entry11325
http://highfieldtale...he-square-root/
For other square root methods,
http://en.wikipedia....ng_square_roots
Baxter
#3 Corey Kosak
Corey Kosak
  • 276 posts
  • LocationHoboken, NJ
Posted 04 December 2011 - 11:27 PM
Make a call to Math.Pow( a, b )
#4 Novice Alex
Novice Alex
  • 59 posts
Posted 04 December 2011 - 11:36 PM
Do note that latest version does not work for this function.
#5 baxter
baxter
  • 415 posts
Posted 05 December 2011 - 03:04 AM
I decided to translate the function that I referenced. I'm not quite sure how it works, but it gives the right answer.
Imports Microsoft.SPOT
Imports SecretLabs.NETMF.Hardware.NetduinoPlus
Module Module1
    Sub Main()
        'Windows calculator  = 351.36323577745011426077534810366
        'sqrt1               = 351.36323577745009
        'exponentiation sqrt = 351.36323577745009
        Debug.Print("sqrt1 = " & sqrt1(123456.123456).ToString)
        Debug.Print("exponentiation sqrt = " & exponentiation(123456.123456, 0.5, 0.000000000000001).ToString)
        'Windows calculator = 43345080833350.462136968781988806
        'exponentiation     = 43345080833349.852
        Debug.Print(exponentiation(12345, 3.333, 0.000000000000001).ToString)
        'Windows calculator = 783029.35629994585528611534553745
        'exponentiation =     783029.35629995051
        Debug.Print(exponentiation(576, 2.1351, 0.000000000000001).ToString)
    End Sub
Public Function sqrt1(ByVal num As Double) As Double
        'http://openbookproject.net/thinkCSpy/ch06.html
        Dim approx As Double = num / 2.0
        Dim better As Double = (approx + num / approx) / 2.0
        While better <> approx
            approx = better
            better = (approx + num / approx) / 2.0
        End While
        Return approx
    End Function
    Public Function Abs(x As Double) As Double
        Return If(x <= 0, -x, x)
    End Function
    Public Function exponentiation(ByVal base As Double, ByVal exp As Double, ByVal eps As Double) As Double
        'Recursive function
        'http://stackoverflow.com/questions/3518973/floating-point-exponentiation-without-power-function
        If (exp >= 1) Then
            Dim temp As Double = exponentiation(base, exp / 2, eps)
            Return temp * temp
        Else
            Dim low As Double = 0
            Dim high As Double = 1.0
            Dim sqr As Double = sqrt1(base)
            Dim acc As Double = sqr
            Dim mid As Double = high / 2
            While (Abs(mid - exp) > eps)
                sqr = sqrt1(sqr)
                If (mid <= exp) Then
                    low = mid
                    acc *= sqr
                Else
                    high = mid
                    acc *= (1 / sqr)
                End If
                mid = (low + high) / 2
            End While
            Return acc
        End If
    End Function
Baxter
#6 Netduinerd
Netduinerd
  • 10 posts
Posted 05 December 2011 - 07:48 AM
I confirm Math.pow function doesn't exists in the latest .NET MF implementation. Anyway I had wrote my own power function like the first Baxter's post, now I'll understand all of ur suggestions guys. Thanx a lot, Netduinerd
#7 Corey Kosak
Corey Kosak
  • 276 posts
Posted 05 December 2011 - 12:57 PM
Sorry for my bad advice. I should test these things before opening my mouth :(
