Problems with USB Port in WIndows 7
Posted 30 November 2011 - 01:05 AM
Michael O'Neill
mikeo@mikeo.biz
Posted 30 November 2011 - 01:22 PM
http://wiki.netduino...ep-by-step.ashx
I had a similar problem but I had to modify my registry to get it working. I have Windows 7 ultimate but it is 32 bit not 64.
I have other PC's so I first made sure my Netduino was working on another PC.
Do you have a friend with a PC you could try yours on? I would doubt the USB port on the Netduino is bad.
I hesitate about posting the following but I got nowhere with my issue until I completely removed the USB driver info from the PC registry.
I could NOT load a new driver until I completely removed the old driver reference from the registry. In fact once the registry Key was removed windows loaded a new driver after plugging the Netduino in.
I will post what I had to do but please DO NOT take messing around in the registry lightly.
Maybe you have a friend that could do it for you if you are not experienced doing this?
I have no idea about what you can do, or not do, with regards to chanding anything in the PC registry.
I take no responsibility if things go wrong.
Anyway.. Here goes..
I 'fixed' mine by removing the KEY/Sub-Keys using regedit.
I removed the Key group, rebooted the PC and then plugged in the Netduino USB. It worked for me.
I found my USB port at: I have no idea if this is true in your case.
Be warned!
You can trash your windows installation if you do the wrong thing in the registry. I know from past experience.
PLEASE NEVER edit your registry unless you know what you are doing. Even if it is backed up.
Backups do not work if you cannot reboot to load it! Been there, did that.
My Netduino USB ports were found at registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\USB\VID_22B1&PID_1000
I assume (without proof) that a 64 bit machine is similar.
Look for something like " MFG @oem28.inf,%secretlabs%;Secret Labs LLC " in the sub-keys under the main key shown above.
You may find several sub-keys depending on what USB ports you have plugged the Netduino USB cable into.
Each USB port you plug into you will find a new subkey listing.
(As far as I know this is true)
Good luck and the registry should be OK if this is the only Key deleated.
Posted 30 November 2011 - 02:36 PM
Posted 30 November 2011 - 04:31 PM
Posted 30 November 2011 - 06:08 PM
Hi Mikeo2721,
I wear out a USB port on my computers just about every year. They're rated for thousands of insertion cycles--but it's amazing how many times I unplug/plug things around here testing engineering samples, etc.
Anyway, let's make sure we get you up and running...
Chris, If you wear out a USB port on a motherboard that can be an expensive fix ;-)
Have you considered using a USB extension cable (male on one end, female on the other) and leaving it plugged into the PC continuously? That way it would be the extension cable that would wear out, not the socket on the PC.
Posted 01 December 2011 - 03:12 AM
I know, especially on a laptop! Which is probably why I always buy Dell's CompleteCare service. The USB extension cable is a good idea.Chris, If you wear out a USB port on a motherboard that can be an expensive fix ;-)
BTW, a big part of why we build Netduinos to be fairly rugged...they have to pass the "Chris mistreating hardware" test
Posted 01 December 2011 - 06:23 AM
"Maybe it's because you're a crap programmer"
Posted 02 December 2011 - 03:26 AM
Michael O'Neill
mikeo@mikeo.biz
Posted 02 December 2011 - 07:39 AM
Do you have a different cable you can try, I have this problem with one of the uUSB cables I have around here.I appreciate it.
I tried on three different computers in my house and had the same issue on each. I see the device in the device manager but the driver fails to load.
I am going to back up my machine tonight, then change the registry as suggested (yes I will be careful) and also flash the card. We will see if any of these options work. I already contacted MakerShed for a RMA if I need to send it back but would love to get it fixed here to save time if possible.
I will let everyone know what I find.
Mikeo
Posted 02 December 2011 - 02:50 PM
Posted 02 December 2011 - 05:25 PM
Yep - Tried different cables as well. I have now tired on 5 different computers and all can't find a driver for the device. I tell it I have the driver disk, point it to the driver, and it still comes up as unrecognizable.
I am thinnking more and more that I have a bad USB port on the device although I know that is unlikely.
Michael O'Neill
mikeo@mikeo.biz
Posted 02 December 2011 - 05:27 PM
Yes, try another cable. Some of the cables that come with cell phones only have the power pins wired for charging. Data wires are absent. I have one and spent an hour trying to sync my WP7 before I figured it out.
-Valkyrie-MT
Hummm - Actually the cable I bought from Best Buy was for a mobile phone. I am throwing money at this thing left and right to diagnose. I may just be better off buying a new card.
Michael O'Neill
mikeo@mikeo.biz
Posted 02 December 2011 - 06:30 PM
Michael O'Neill
mikeo@mikeo.biz
