How to power a Netduino Plus without USB or VDC "plug"?
9 replies to this topic
#1 rockinthesixstring
rockinthesixstring
  • 4 posts
Posted 29 November 2011 - 01:53 AM
I'm trying to figure out a way to power my Netduino Plus by directly attaching power leads to the board rather than relying on the plug or the USB. The reason for this is that I'm trying to power a 12V LED strip and I'd like to use a transistor to do so. Therefore the power lead will wire directly into both a transistor AND the netduino. Thanks.
#2 Stefan
Stefan
    Moderator
  • 1965 posts
Posted 29 November 2011 - 07:31 AM
Hi rockinthesixstring and welcome to the boards, On your Netduino you have a Vin pin, you can directly supply 7.5-12V to that.
#3 AJB2K3
AJB2K3
  • 46 posts
Posted 29 November 2011 - 07:40 AM
*snip*
Thanks.
I was advised to use TIP120 transistor for my projects as they can also handle the PWM switching if you want to be able to dim the lights.
"Maybe it's because you're a crap programmer"
#4 rockinthesixstring
rockinthesixstring
  • 4 posts
Posted 29 November 2011 - 07:01 PM
Thanks Stefan, that's what I thought it was for, but I wasn't sure. The specs page doesn't speak to that at all.
#5 rockinthesixstring
rockinthesixstring
  • 4 posts
Posted 29 November 2011 - 07:02 PM
@AJB2K3 can you speak to the TIP120 transistor a little bit? I'm not very familiar with supplies yet and I'd like to know what it achieves.
I just bought 8 of these
IRF540N IRF540 "IR" MOSFET N-Channel 33A 100V
#6 AJB2K3
AJB2K3
  • 46 posts
Posted 29 November 2011 - 07:35 PM
I could but It doesn't speak back ( sorry I see your using a translations service) I'm still trying to get back into electronics after a 7 year absence so don't know the correct terminology.
I chose this because its often in the diagrams found online in this kind of project.
Sorry not failure with this component
#7 Mario Vernari
Posted 30 November 2011 - 05:10 AM
Hello Rockinthesixthstring! Could you explain better your goal? I meant that you only have to power the Netduino, while AJB2K3 is talking about the PWM. These are totally different contexts, I guess. Cheers
#8 rockinthesixstring
rockinthesixstring
  • 4 posts
Posted 30 November 2011 - 07:34 AM
I'm bringing power in from a "wall wart". It's then going to power the Netduino as well as supply power to a 12V LED strip. The netduino is simply going to be switching the RGB of the LED strip.
#9 Alexa
Alexa
  • 5 posts
Posted 30 November 2012 - 08:40 PM
What kind of light strip is it? I'm looking at signaling some WS2811 12v strips, but I'm not sure I can do it with 5v logic...
#10 carb
carb
  • 352 posts
Posted 30 November 2012 - 09:51 PM
Thanks.
Rockinthesixstring,
What would suggest is a female pigtails and a wye barrell connector, I have several types that I purchased from Ebay and use them to power relay boards etc.
Chuck
