SNMP???
Posted 14 November 2011 - 12:44 PM
Posted 14 November 2011 - 04:59 PM
Posted 10 June 2012 - 07:39 PM
Posted 10 June 2012 - 08:20 PM
You could use this one:Any update on this? Any chance SNMP has now made it into the .NET MF?
http://netmftoolbox....NET.SNTP_Client
Posted 11 June 2012 - 11:30 AM
Stefan, the SNMP is dramatically different from the SNTP. The first one is for registry/variable data exchange, the second one is for mailing.
I agree on the too-similar name: I often confuse them!
Posted 11 June 2012 - 11:36 AM
Oh my apologise. I indeed misread it. I also confuse it with SMTP often, darnStefan, the SNMP is dramatically different from the SNTP. The first one is for registry/variable data exchange, the second one is for mailing.
SNMP, sorry, can't help you with that at the moment.
Posted 11 June 2012 - 12:26 PM
- SNMP (Simple Network Management Protocol used for reporting system statuses etc.)
- SMTP (Simple Mail Transfer Protocol outgoing email, rarely used for incoming)
- SNTP (Simple Network Time Protocol time sync against an authoritive clock)
1) In the case of SNMP i dont think a netmf lib exists yet but there are quite a few FOSS C# implementations which could be cut down to size for netmf, but it really depends on your feature requirements...
2) You can send email by opening a socket connection and sending an appropriate string more info here
3) You can use the SNTP client in the Netmf toolbox.
That said i am leaning more and more towards using ND+'s to do as little as possible when it comes to protocol based stuff and instead let a server (read as any pc with a nic) act as a protocol proxy for me, that way i don't have to compromise on protocol compatibility and also conserve the limited resources of a ND+ for application logic instead of protocol/transport logic.
Nak.
Posted 16 August 2012 - 07:58 PM
Sharp SNMP (#SNMP) Library
The library looks a bit large, so I'm not sure if it will fit on the netduino. However, it is open source.. so you could possibly strip it down a little.
I did not check it out yet, though. I might dive into it this weekend. I really want to poll my Airport Extreme for current throughput and use an analog gauge of some sort to display it.
Sounds simple enough.. (how most of my hair-brained ideas start)
I cant read. It's for the Compact Framework.. not Micro
Posted 17 August 2012 - 06:31 PM
