Markus, I just wanted to chime in and thank you again for all your hard work on this. I am going to give this a try tomorrow of my N+2's. Really awesome project, great work man!
i try to convert NeonMika.Webserver to Framework 4.3 with no success. Is somebody out how can Point me in the right direction.
Problem: I changed all the Projects to 4.3, compiling is ok, but it seems that the deployment 'blocks' my N2P.
Even with MFDeploy there is no answer from N2P ping... is freezing.
Peter
Sorry that I haven't answered for so long. I cannot help you with that problem because I just have a NP1. Have you ever figured out how to get it working?
Jim
Thanks Jim! It's always great to hear so kind words.
Please let me know how NeonMika.Webserver works for you. If you have questions don't hesitaste to aks
Markus, this is really awesome! One of my n+2 is used as a controller for a chicken coop door, temperature sensor, daylight sensor, etc. I was never happy with how it was working. In less than 20 minutes using your webserver I have a project that is working MUCH better/cleaner and is easily upgradeable! The one thing I would mention so it would get updated in the documentation is that the RequestReceivedEventArgs is just Request now, but that was easy enough to figure out.
Thank you and all who contributed to this project - this just lets you concentrate on doing the fun stuff!
Best regards,
Jim
I'm always happy when my webserver code can help people cutting down their development to the important part without caring about the whole networking stuff
Good that it worked out without problems for you
Thanks for the tip with the documentation, i will fix this
Great crashed the Netduino Plus 2 after loading a webpage will not boot now!
needs to be re-flashed.
I think secret labs needs to remain a secret and develop the 1980 watch!
As old NETMF with missing dot.net functions and SL's stack hacked stack is pants!
If You like flashing a blue light then your CLR will just do it!
That's why Microsoft dropped it. it so Sloooow!
Learn C or Buy a PI!
Hello Dave!
I'm sorry that the Netduino doesn't work out for you as expected.
I'm also sorry that NeonMika.Webserver doesn't work on you device, but I can tell you that I got many feedbacks from different people that it works on their devices without problems.
I would try to help you out, but according to the "sound" of your text you are not really interested on working together on a solution.
And thanks for the advice, but I already know C (I'm currently writing my bachelor thesis with it) and a also own a Raspberry Pi
Good luck Dave,
I run multiple projects without any problems.
So what are you doing wrong...
Just ranting in these forums does not help you, And does not correctly show how awesome these devices are.
And I am one of the most critical people running around in these forums.
Best regards and have fun with your PI that runs Mono with C# ....
Olaf
Thanks for your reply Olaf.
It's great to hear that you run different projects without problems
And always keep critical, supporting feedback is always welcome!
The more informative feedback, the better a software can get
I just wanted to report that I was able to get NeonMika.Webserver working on my N+2 with framework 4.3.1 with ease. There are 2 things that need to be done.
1) For each project, right-click>Properties>Application and update the Target framework to ".NET Micro Framework 4.3"
2) For each project, expand the References folder, remove any reference to Microsoft.SPOT.* and SecretLabs.NETMF.* and re-add the 4.3.1 versions of each
I'm trying to convert my NeonMika.Webserver soloution for my Netduino +2 from framework 4.2 to 4.3, but i am stuck with an error i do not know what to do about.
I followed the guide written in the post above.
1. Changed target framework for all projects included in the soloution from 4.2 to 4.3
2. Deleted 4.2 references and re added 4.3 references instead.
The error i am getting in VS2015 :
SeverityCodeDescriptionProjectFileLineSuppression State
ErrorCS1579foreach statement cannot operate on variables of type 'string' because 'string' does not contain a public definition for 'GetEnumerator'JSONLibC:\Users\bayzt\Desktop\Ny mappe\Framework\FastloadMedia.NETMF.Http\JSONLib\Json.cs43Active
