I become crazy because wiring?
29 replies to this topic
#21 Mario Vernari
Posted 28 October 2011 - 11:49 AM
Dops, I want anything but hurting you!...Your desperation is very common when you make experience: I share it!
Capita spesso anche a me! (=it happens often to me as well)
Please, could you try to use the very basic SPI way?
Here is the sample configuration:
http://wiki.netduino...figuration.ashx
To set the leds output, use this:
ushort x = 0x55AA; //bitwise array
xspi.Write(x);
I'll stay in touch.
#22 dops
dops
  • 28 posts
Posted 28 October 2011 - 03:23 PM
xspi.Write(x);
I'll stay in touch.
Ok this is the result:
Attached File  WP_000148.jpg   103.76KB   23 downloadsAttached File  WP_000150.jpg   106.62KB   22 downloads
Really i think problem is current voltage.. I don't know other explanations :(
If i use 3V pin, doesn't turn on even a single LED..
I begin to think that an electrical appliance is teasing me :( :angry:
This is used code:
        private static SPI SPIBus;
            // Defines the first SPI slave device with pin 10 as SS
            SPI.Configuration Device1 = new SPI.Configuration(
                Pins.GPIO_PIN_D10, // SS-pin
                false,             // SS-pin active state
                0,                 // The setup time for the SS port
                0,                 // The hold time for the SS port
                true,              // The idle state of the clock
                true,              // The sampling clock edge (this must be "true" for the 74HC595)
                1000,              // The SPI clock rate in KHz
                SPI_Devices.SPI1   // The used SPI bus (refers to a MOSI MISO and SCLK pinset)
            // Initializes the SPI bus, with the first slave selected
            SPIBus = new SPI(Device1);
            DoWorkSlow();
        private static void DoWorkSlow()
            //set-up a one-byte buffer
            byte[] buffer = new byte[1];
                for (int i = 0; i < 8; i++)
                    buffer[0] = (byte)i;
                    SPIBus.Write(buffer);
                Thread.Sleep(500);
#23 Mario Vernari
Posted 28 October 2011 - 03:49 PM
No: the code is not the same I suggested. Your's is displaying sequentially the numbers from 0 to 7, but since they're in fast sequence, you will see only the "7". The "while" is okay, but avoid the "for" loop. Then use the "ushort" buffer, that shifts a word at once.
#24 dops
dops
  • 28 posts
Posted 28 October 2011 - 04:33 PM
Sorry, i don't understand
xspi.Write(x);
isn't possible.. simple because xspi.Write() method accept only arrays of type byte[] and ushort[]
#25 Mario Vernari
Posted 28 October 2011 - 05:13 PM
You're right: my mistake.
Two options:
ushort[] buffer = new ushort[] { 0x55AA };
or:
byte[] buffer = new byte[] { (byte)0x55, (byte)0xAA };
Try now.
#26 dops
dops
  • 28 posts
Posted 28 October 2011 - 06:12 PM
Two options:
or:
Try now.
In fact I had already tried, nothing to do, always the same problem :(
I've changed breadboard.. but nothing.. :(
#27 Mario Vernari
Posted 29 October 2011 - 03:58 AM
I assume you don't own neither a scope, nor a multimeter...
#28 dops
dops
  • 28 posts
Posted 29 October 2011 - 07:29 AM
My uncle has a scope, try to go to make measurements.. :( uff!! (capitano tutte a me!!)
#29 Mario Vernari
Posted 29 October 2011 - 07:36 AM
Cheer up, Dops...this is funny: inspecting and digging into a trouble...not when everything goes right at first time! Within minutes I leave for Rome, I'll be in touch later or tomorrow... Cheers
#30 dops
dops
  • 28 posts
Posted 29 October 2011 - 04:54 PM
yes it's ok, maybe funny, but not in this type of situation, i mean this is a simple circuit.. what happen when i make more complex circuits? .. see you, and thank you ;)
(ti stai avvicinando dalle mie parti, io sono di napoli) :D
