Native code
Posted 05 August 2010 - 06:59 AM
Posted 05 August 2010 - 02:31 PM
Is it possible to call native ARM code from the C# code somehow?
Hi Johan, welcome to the forums!
There are two possible ways to do this.
Today:
Netduino is open source, so we provide the source code. You can create a managed component with raw C++ behind it and then compile it in. If you'd like, I can point out some references on how to do this.
Future:
It's totally possible to load unmanaged (native C++) code at runtime. After all, we'd just need to move the microcontroller's "instruction pointer" to the right place. There are some issues with playing nice in the threading model, giving people power that can come back to bite them, etc. But perhaps we can come up with a good way to handle these as a community--and then build a way to deploy and run unmanaged code into a future firmware release. That would be really cool.
Posted 05 August 2010 - 08:28 PM
Posted 05 August 2010 - 09:16 PM
Is it possible to debug the native code I add in msdev?
C++ code is compiled and debugged through the C++ compiler/debugger (GCC, etc.; we use RVDS and RVICE here)--not Visual Studio. You'd need an ARM dev board with JTAG to really dig in and debug that.
That said, you could do some simple things to debug: flash the LED, write data out via a serial port, write data out into the MFDeploy debug stream, etc. That's actually how we do a lot of our debugging...it's so much quicker and simpler than using RVICE and JTAG.
Posted 06 August 2010 - 06:58 AM
GHI Electronics have developed 'Runtime Loadable Procedure' (RLP) [^] for their ChipworkX module - this may be a good starter...It's totally possible to load unmanaged (native C++) code at runtime. After all, we'd just need to move the microcontroller's "instruction pointer" to the right place. There are some issues with playing nice in the threading model, giving people power that can come back to bite them, etc. But perhaps we can come up with a good way to handle these as a community--and then build a way to deploy and run unmanaged code into a future firmware release. That would be really cool.
Posted 06 August 2010 - 01:31 PM
GHI Electronics have developed 'Runtime Loadable Procedure' for their ChipworkX module - this may be a good starter...
Thanks for the link! Yes, something along those lines would be good. I'll see what we can pull together (if someone in the community doesn't come up with something clever first).
Posted 12 August 2010 - 05:42 PM
Posted 12 August 2010 - 06:27 PM
Please have a look at the following article (pictures are at the bottom), which contains some measurements along with code hints - it is for a different micro (~100 Mhz), but you can get the idea - at least until someone provides the exact results for Netduino...I'm just wondering what are the speed metrics in the managed environment?
Bonus interesting facts:
- Thread switch interval (time slice, quantum) is 20 ms,
- Thread.Suspend() does not stop the thread immediately (it runs until its time slice expires),
- When the CLR calls into any custom interop (i.e. native) code, all managed code threads are suspended
Using Interop in the .NET Micro Framework V3.0,
Thread Management In the .NET Micro Framework
Edited by CW2, 12 August 2010 - 06:29 PM.
Posted 08 June 2011 - 08:56 AM
Chris I'm looking for a way to do this. Can you tell me how to create a managed C++ component and then compile it in.There are two possible ways to do this.
Today:
Future:
Is there support for running unmanaged native C++ code in the current firmware?
Thanks.
Posted 08 June 2011 - 09:03 AM
Check out this Adeneo article. It's actually pretty simple to create a managed code component with P/Invoked C++ behind the scenes.
The only drawback to the current method is that you need to compile your tweaks into the firmware. We're working on a "runtime deployment" scenario for native code...but that will only be a subset of what you can do today. The native interop described in that article gives you full power and deep integration capabilities.
Posted 08 June 2011 - 09:14 AM
Posted 08 June 2011 - 11:24 AM
Posted 08 June 2011 - 08:05 PM
Posted 09 June 2011 - 08:36 AM
Hi Chris,Hi Klop,
We edit the files by hand, as it's generally more flexible. If you follow the example and look at the SecretLabs.NETMF.Hardware libraries in the Netduino firmware source code, that should give you a pretty good template.
The instructions for the SolutionWizard are in the C:\MicroFrameworkPK_v4_1\Documentation\RCLPort.chm file...although they may be a little sparse. Perhaps we should all start a Wiki article and everyone can pitch in their insights and experiences?
There are some changes coming in .NET MF 4.2 which add a GUI around more of the customization process...
Can you tell me why it is necessary to link and build your native C++ code into the MF framework. Why not just link it with the Netduino firmware from you guys. Am I missing something or have I completely got it all wrong?
Thanks.
Posted 09 June 2011 - 09:36 AM
The Netduino firmware is a superset of the .NET Micro Framework. You can certainly link additions to the object files that make up the Netduino firmware--but that's more or less the same thing as compiling it in.Can you tell me why it is necessary to link and build your native C++ code into the MF framework. Why not just link it with the Netduino firmware from you guys. Am I missing something or have I completely got it all wrong?
We are designing an option to let you deploy native code as part of a Visual Studio solution--but that will be a limited subset of functionality compared to what you can do with the current method.
Posted 09 June 2011 - 01:04 PM
That sounds very cool. When do you think you will release this? Was that with the upcoming MF 4.2 release sometime in "august"?The Netduino firmware is a superset of the .NET Micro Framework. You can certainly link additions to the object files that make up the Netduino firmware--but that's more or less the same thing as compiling it in.
Posted 09 June 2011 - 07:11 PM
It's largely a community project, although we're steering it and contributing as well. No definitive timeframe and it will come in "test pieces", but we'd like to start testing some concepts later this summer.That sounds very cool. When do you think you will release this? Was that with the upcoming MF 4.2 release sometime in "august"?
Posted 19 May 2012 - 08:45 PM
