Cannot Connect to Pachube
Started by phutton11, Oct 05 2011 10:46 PM
Posted 05 October 2011 - 10:46 PM
Long time micro-coder but new to Netduino Plus system. I just recently acquired a Plus unit after buying the book "Getting Started with the Internet Things". The book focuses on the Plus unit and the Pachube data sharing website. Seemed like a great idea, but I cannot get the Plus unit to connect to the outside world.
After completing the traditional LEDBlink & Voltage Divider programs to better understand the MS .NET Micro Framework environment, I loaded the books sample "HelloPachube" azpplication (after creating my own Pachube account and feed). Every time I tried to run it (no build errors) I received the following errors:
#### Exception System.Net.Sockets.SocketException - CLR_E_FAIL (1) ####
#### Message:
#### Microsoft.SPOT.Net.SocketNative::getaddrinfo [IP: 0000] ####
#### System.Net.Dns::GetHostEntry [IP: 0008] ####
#### System.Net.HttpWebRequest::EstablishConnection [IP: 00e1] ####
#### System.Net.HttpWebRequest::SubmitRequest [IP: 0013] ####
#### System.Net.HttpWebRequest::GetRequestStream [IP: 0008] ####
#### Gsiot.PachubeClient.PachubeClient::CreateRequest [IP: 003e] ####
#### Gsiot.PachubeClient.PachubeClient::Send [IP: 0025] ####
#### HelloPachube::Main [IP: 0065] ####
#### SocketException ErrorCode = 10060
#### Exception System.Net.WebException - 0x00000000 (1) ####
#### Message: host not available
#### System.Net.HttpWebRequest::EstablishConnection [IP: 00f1] ####
A first chance exception of type 'System.Net.WebException' occurred in System.Http.dll
System.Net.WebException: host not available
It suggests that the Host is not there. But manualy creating the messages and sending them via browser results in a correct response.
I used the MFDeploy tool to verify that the Plus unit was obtaining an IP address (192.168.5.100) and the correct MAC address is loaded.
But using Wireshark (see attachment) it appears that the Plus unit is not making a live connection. The application just seems to be in a loop trying to get a connection but failing every time.
Can anyone help me here? BTW when I use a regular Arduino board with am eithernet shield I have no problems. Does it sound like I might have a bad board?
Posted 06 October 2011 - 08:29 AM
Hi phutton11,
with the current Netduino Plus firmware, there seem to be occasional problems with DHCP. Maybe the IP address of your Netduino Plus is just a stored default value, and was not really obtained via DHCP? Could you try to switch off DHCP in MFDeploy and assign a suitable static IP address?
Best regards
Cuno
Posted 06 October 2011 - 12:52 PM
I have seen N+ hang on a socket connection and also with DNS. I would try hard coding the target IP address. The other thing to bare in mind is the networking using a lot of memory which the then causes indirect and undefined errors, especially if you have a lot of other stuff going on.
Posted 06 October 2011 - 05:13 PM
What has worked well for me is to do a DNS lookup once and use the IPEndPoint from then on, something like;
private static IPEndPoint wwwaddresscom; ... static Socket Connect(string host, int timeout) { if (wwwaddresscom == null) { var hostEntry = Dns.GetHostEntry(host); var hostAddress = hostEntry.AddressList[0]; wwwaddresscom= new IPEndPoint(hostAddress, 80); } if (wwwaddresscom == null) return null; ... }
