Xbee Wrong Text - Help
Started by Adamos, Sep 27 2011 09:24 PM
5 replies to this topic
Posted 27 September 2011 - 09:24 PM
Hello guys,
I ve a problem when i am sending data from netduino to the xbee attached on the pc , i m receiving some bad text and after the text that i wanted to send.
I ve attached a screenshot with the code and the x-ctu application.
Please help me!!!!
Sorry for my bad english.
Posted 23 October 2011 - 09:44 PM
Check your baud
Posted 30 October 2011 - 02:12 PM
Check your baud
Thanks, which rate you suggest?? i currently use 9600
Posted 30 October 2011 - 05:48 PM
Hi,Thanks, which rate you suggest?? i currently use 9600
The baud rate is important, but the speed doesn't matter. As long as both the XBee and Netduino have the same setting. So if you set them both at 9600 it should work fine!
Posted 03 November 2011 - 03:42 PM
Both Xbee and Netduino have the same setting!
Posted 04 November 2011 - 02:56 PM
what's the result using two terminals (e.g open X-CTU twice, no netduino)?
